almost there haha Its going to take even longer now...check it out I had to cut the fender it was welded to the radiator mount, so ill be at pick n pull sooner or later, I remember seeing a 74 and the front end was immaculate.
i put that exact timing chain on my 352 but it chewed on the back of the timing chain cover since the double roller was wider than stock those little chunks of metal aren't good to a motor double check fitment yet then again could of been because my cam was walking but always good to double check
I concur smoke I will check that...I did compare the 2..new with the old...not much difference in size..the old gear was a single beefy gear...are these stock
Also...what I thought was TDC I was 2 degrees off so the 2 dots wasn't lined up.. I just marked a new 0 on the harmonic balancer dose anyone approve? lol
