C8AE-H heads
Old Aug 8, 2012 | 02:11 AM
FordmanShane's Avatar
FordmanShane
C8AE-H heads
Can I put a pair of C8AE-H heads on my 360?
Old Aug 8, 2012 | 07:06 AM
baddad457's Avatar
baddad457
Yes, that's the heads they came with from 68-71
Old Aug 8, 2012 | 07:09 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
And even though they probably have the right exhaust manifold bolt pattern, check it before you slap them things on
Old Aug 8, 2012 | 12:34 PM
FordmanShane
No overkill.. cool, If I recall correctly I think they had the 16 bolt pattern.. I will double check that ..thanks
Old Aug 8, 2012 | 09:39 PM
baddad457's Avatar
baddad457
They would have been off a GT390, they'd have had 14 holes drilled and tapped. Unless someone drilled the two center, bottom holes, ala 428CJ. If they were off anything else, they'd have only the 8 vertical holes.
Old Aug 8, 2012 | 10:17 PM
FordmanShane
Talked to the owner 8 bolt pattern... the heads I seen were cj ..that's great tho no need to drill and tap.. is there a difference other than the bolt pattern? is it still a gt head? 2.08 1.65? ..360 gt haha awesome
Old Aug 8, 2012 | 11:34 PM
FordmanShane
Dang https://www.ford-trucks.com/forums/4...ze-c8ae-h.html well.....
Old Aug 9, 2012 | 05:39 AM
baddad457's Avatar
baddad457
C8AE-H is the "generic" FE head for 68-71. Std sized valves, unless someone's spent some money and upgraded them. 16 bolts doesn't signify a CJ head, anyone could have drilled the extra bolt holes at this point in time, just as I have done in the past. Casting numbers are the only way to ID a head
Old Aug 21, 2012 | 07:17 PM
FordmanShane
whey were actually the 8 bolt type
ford79man91
Jun 20, 2011 10:33 PM
Fordworth
Ford Truck Parts for Sale
Apr 26, 2011 10:13 PM
1ford1
Aug 30, 2006 10:04 PM
banjopicker66
Nov 30, 2004 12:07 PM
bsprowl
Jan 7, 2002 06:42 PM
