Compressor Wheel Help
Old Jun 5, 2012 | 05:02 PM
jsmahan's Avatar
jsmahan
Ok Guru's, I'm exhausting all known resources. I'm working on a 2000 F-650 with the 7.3. I need to determine which compressor wheel will fit this. I have one for the GT 38 but this has a GT 3776D. Will these use the same wheel or what part number do I need?
Old Jun 6, 2012 | 07:53 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Here is a couple for the stock turbo. Give Clay a call and he will get you what you need.
Riffraff Diesel Performance Parts: Diesel Borg Warner Anti-Surge Compressor Wheel | Garrett GTP38 Compressor Wheel 99.5-03 - Compressor Wheels
Old Jun 6, 2012 | 10:58 AM
jkidd_39's Avatar
jkidd_39
The only difference in those wheels is the early 99 or wicked wheel or a late 99-03.
Either will work.
Good luck
Old Jun 6, 2012 | 01:48 PM
jsmahan's Avatar
jsmahan
Thanks for the replies. The turbo folk around here tell me these two will not interchange ( they think). The current wheel looks nothing like a wicked wheel or the 99-03 wheel. It also has the ported shroud intake. I cannot find part numbers to compare these two.
Old Jun 6, 2012 | 02:12 PM
jkidd_39's Avatar
jkidd_39
Does the housing have a recessed area for the wheel to sit in? The gt38 is a self balancing unit. Where as most Borg Warner turbos require balencing.
I would put a wheel in and see how it feels. I have never seen any other turbo on a 7.3 other that the gt38 and the obs unit from the factory. Is the truck intercooled??
Old Jun 6, 2012 | 02:33 PM
jsmahan's Avatar
jsmahan
It is intercooled. This particular unit is being very difficult to locate parts for. I found one company who can get the wheel and it does not appear to be the same. I'll update when I lay hands on it.
Old Jun 6, 2012 | 03:00 PM
jkidd_39's Avatar
jkidd_39
Much appreciated. Now I'm curious
Old Jun 6, 2012 | 03:29 PM
73ferdf250highboy's Avatar
73ferdf250highboy
Can you post pics? I might know some folks...
Is it an .54 a/r?
Old Jun 6, 2012 | 03:36 PM
jsmahan's Avatar
jsmahan
It'll be a few days for pics. Got some other things going on. I will say the DP chip woke this thing up. Waiting on gauges and comp wheel to turn it loose. May get to bring it to RRE this year. It's the 1st 7.3 F650 I've seen.
Old Jun 6, 2012 | 03:54 PM
73ferdf250highboy
Here's part numbers for the turbo gt3776
Part# 776243-0031
Turbo part # 452159-0001
compressor housing# 436032-0010
Old Jun 12, 2012 | 11:59 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I was able to find that compressor wheel for you if you still need it. Just let us know, Thanks
Old Jun 12, 2012 | 01:45 PM
Bonanza35's Avatar
Bonanza35
I'd like to see pictures also. Of the whole thing would be great.
Chet
Old Jun 12, 2012 | 03:48 PM
jsmahan's Avatar
jsmahan
I appreciate the the replys. Clay, I've sent you a couple emails and I appreciate your help. I supposedly have one on order but we'll see. Trying to upload photos from iPhone but not having a lot of luck.
Old Jun 17, 2012 | 08:20 PM
jsmahan's Avatar
jsmahan
Update: The company who said they could get the wheel failed to produce. Clay has advised he can get it but with a 6-8 week wait. I'm considering placing a stock 2001 turbo on it if it will bolt up and all tubing matches. I am having some issues finding comparison charts for the 2. Garrets website doesn't even list the gtp38. They do have specs for the 3776 unit. I may try, as someone mentioned earlier, to place a ww on this unit to see if it will fit before I swap entire units. This one is very frustrating to say the least.
Old Jun 21, 2012 | 03:52 PM
jsmahan's Avatar
jsmahan
Ok, I ordered a wheel and of course it was wrong. Before calling Clay and begging for help, I tore into the turbo. After getting into it, I noticed several things. First off, it turns backwards compared to the 38r. Then I inspected the crack on the fin. I could not feel it at all. Turns out it was just a scratch in the outer covering. Cleaned it up, put it back together and sent him on his way a happy customer. Not sure what I'll do if he ever has turbo problems.
RandomNewGuy
15
Aug 10, 2015 08:09 PM
spcw1234
Jun 19, 2011 05:55 PM
dt444e
18
Aug 8, 2009 11:32 AM
Bigfwt04
Oct 27, 2008 03:54 PM
ramtruckman
Mar 15, 2004 07:57 AM
