E99 Compressor Wheel?
Old Aug 4, 2010 | 07:24 PM
spcw1234's Avatar
spcw1234
I have an early 99 F250 that has a dusted compressor wheel. The bearings appear to be fine, so I just need to replace the compressor wheel. I am reading the wicked wheel is actually the same as the stock wheel I already have. However when I go to buy it the description for the WW say for 99.5-03. Will this wheel fit my stock turbo as a replacement? Thanks in advance.
Shawn
Old Aug 4, 2010 | 08:10 PM
F350-6's Avatar
F350-6
Welcome to FTE.
Yes the wicked wheel is the same as your stock wheel. It's sold to the 99.5 - 03 turbos as a cure for turbo surge. You'll be fine ordering that for your truck.
Since you're calling it a wicked wheel, are you looking at Dieselsite? Many folks sell the exact same wheel with a different name. Here's a link that has a little better description of the same wheel Replacement O-rings for Ford Diesel Engines
Old Aug 4, 2010 | 08:23 PM
spcw1234's Avatar
spcw1234
Thanks for the fast reply!
I was actually looking at this item here.
Xtreme Diesel's X-Wheel Compressor Wheel
I assume they are all the same. By any chance do you know the OEM part number for this compressor wheel so I can check the price through my work's dealer?
Shawn
Old Aug 4, 2010 | 08:46 PM
F350-6's Avatar
F350-6
Sorry, don't know the part number, but the link you provided is the same wheel. I'd recommend pulling the turbo to change the wheel, which of course means you also need to buy new turbo pedestal o-rings.
Then you get to ask yourself questions like, should I just gut and plug the EBPV when I have the turbo out? Should I upgrade to bellowed up pipes while the turbo is out? Is there another FTE member who lives close to me that might offer to help me do this?
Old Aug 4, 2010 | 11:27 PM
crazymut's Avatar
crazymut
I have an unused one I am looking to have someone put to use. I bought it figuring I would get surge with my mods but I did not. I never installed it and it is sitting in my living room.
Old Aug 4, 2010 | 11:34 PM
BigAlsPSD's Avatar
BigAlsPSD
Can you PM me what you would like to have for it?
Old Aug 5, 2010 | 05:21 AM
spcw1234's Avatar
spcw1234
I do plan to pull the turbo, replace pedistal o-rings and gut the EBPV. In for more info on upgrading the up pipes, what kind of improvement can I see from this?
Shawn
Old Aug 5, 2010 | 06:15 AM
F350-6's Avatar
F350-6
Shawn
It eliminates boost leaks and it prevents you from having to pull the turbo later to fix any leaks that may (or some say will) show up.
Welcome to Pocket's International UP-Pipe Replacement Web Page
Old Aug 5, 2010 | 07:21 AM
spcw1234's Avatar
spcw1234
Wow, thanks for that link. I will have to read through that and consider doing that also!
Shawn
Old Jun 19, 2011 | 04:55 PM
knuckleheadnut's Avatar
knuckleheadnut
compressor wheel photos
Compressor Wheels: photos of 94 to early '99 Borg Warner, '99-03 Garrett OEM and GTP38R for 7.3 Powerstrokes. thought I'd just post some here since the thread seemed appropriate. additionally-there are top, profile and bottom (inner) shots of all 3 styles in my albums. profiles only here. sorry they're so big! photos display in order as listed.
Old Jun 19, 2011 | 05:55 PM
leekingen's Avatar
leekingen
forget the bellowed uppips, thay will not work on early 99 trucks.
Renron
19
Jan 6, 2017 10:56 AM
10shots
Jan 6, 2017 10:22 AM
Ezalycasaid
31
Mar 29, 2016 09:53 AM
DanielT28
Nov 6, 2015 01:35 AM
Firefighter 1406
44
Apr 10, 2014 12:58 PM
