STARTUP GROWLING NOISE
Old Jun 3, 2012 | 10:18 PM
mig25's Avatar
mig25
Question STARTUP GROWLING NOISE
Has anybody come up with a resolution for that growling noise on start up on 5.4 engines ?
This is that horrible noise , like the fan clutch is engaged noise on start up when the truck sits for a day or so.
I have done much research here, I did read older posts, Ford has said it is normal, some folks say it could be the a/c compressor, I kept thinking it could be the power steering pump. I recently replaced my radiator fan clutch.
Still sound persists.
Any input on this issue ?
Old Aug 24, 2012 | 03:53 PM
mig25's Avatar
mig25
START UP NOISE
UHUMMMM.... I guess nobody came up with a solution for the start up noise, well this noise is kind of embarrassing when cranking the truck in front of other people.
It only happens when the truck is sitting for few hours.
Funny thing it never happens in the morning....
Old Aug 24, 2012 | 07:43 PM
Moto Mel's Avatar
Moto Mel
You might want to convert to electric fan(s), after you prove to yourself that the fan is the cause of the noise.
Old Aug 28, 2012 | 01:57 PM
expydaddy's Avatar
expydaddy
Get a mechanics stehescope or a piece of long hose. Have someone start the car up and go listening! Be careful of the fan blade and belt whizzing by. Mine started a noise and it was the pulley above the tensioner pulley. good luck.
Old Aug 30, 2012 | 09:58 AM
alloro's Avatar
alloro
Take the belt off and try starting it. If the noise is gone you've at least narrowed the problem down to one of the pulleys.
Old Sep 20, 2013 | 08:47 AM
mig25's Avatar
mig25
Thumbs up START UP GROWLING NOISE
Woohoo.... I have found the cause of the growling noise on start up when the truck is sitting for more than 8 hours.
I had a suspition as well as someone mentioned in other posts it was the A/C compressor.
Last month my A/C broke down, all the freon leaked out. Suddenly I no longer have A/C , as well as the growling noise is gone on start up.
Further research just confirmed my suspitions IT IS INDEED THE A/C system.
Below is a copy of a page from the repair manual. I am about to repair my A/C system, upon reading the manual this came up :
Old Sep 21, 2013 | 01:09 AM
timbersteel's Avatar
timbersteel
Thanks for the update. I found this very interesting and informative. I always make sure to shut my air conditioning off when its no longer needed after long drive or when its been used for an extensive amount of time. Guess that doesn't matter when its been handled by PCM.
Old Sep 21, 2013 | 11:31 AM
alloro's Avatar
alloro
Most people that have the electronic climate control system don't realize that as long as it is set to 'automatic' that the compressor runs continuously.
Pest007
Jul 18, 2016 11:44 PM
nix4x4
Jun 27, 2013 05:58 AM
zombiesawyer
Jan 26, 2011 10:55 PM
jam105
6.4L Power Stroke Diesel
Sep 4, 2007 07:37 PM
ultimatenavi
Nov 21, 2004 11:17 PM
