Cam swap, Now knock. problem!!!
Old Jun 3, 2012 | 09:57 AM
kid1994's Avatar
kid1994
Angry Cam swap, Now knock. problem!!!
Well I swaped the cam in my 1994 f150 302, and i noticed a slight knock os i took the driverside valve cover off and a rocker was loose but the bolt was tight. i thought it was a bad lifter until I started turning it by hand and checked the others. when the lifter is down they are loose?
Old Jun 3, 2012 | 10:26 AM
Conanski's Avatar
Conanski
Exactly what cam did you install?
Are the pushrods still straight?
Old Jun 3, 2012 | 02:21 PM
kid1994's Avatar
kid1994
A Ford racing cam. and the one pushrod i pulled was straight. Also i did change the springs, so?
Old Jun 3, 2012 | 05:07 PM
Conanski's Avatar
Conanski
Originally Posted by kid1994
A Ford racing cam.
A Ford racing roller cam? Be more specific.
Old Jun 3, 2012 | 07:08 PM
kid1994's Avatar
kid1994
1985-up FORD-MERCURY, 302 cu in H.O. V8
grind number m-6250-E303
firing order 1-3-7-2-6-5-4-8
valve setting :HOT /intake .000 /Exhaust .000
Max Lift| intake 110* |exhaust 110*
lift| intake @ cam .311| @ valve.498 | rocker 1.60
exhaust @ cam .311 |@ valve .498 |
need more? I have the card lol
Old Jun 5, 2012 | 07:49 PM
kid1994's Avatar
kid1994
Question
If i pull a pushrod will it just prime up. Cause i pulled it them put it back in and the knock got worse.???
F-250 restorer
Dec 28, 2010 10:29 PM
pipman76
Aug 29, 2009 02:54 PM
austynn2001
Aug 27, 2006 12:43 AM
XolieX
Nov 3, 2005 08:18 AM
tbolt 460
Oct 20, 2003 08:57 AM
