solids on a hyd cam
Old Oct 19, 2003 | 07:37 PM
tbolt 460's Avatar
tbolt 460
Question solids on a hyd cam
can you run solid lifters on a hydrolic cam shaft???
Old Oct 19, 2003 | 08:01 PM
jwtaylor's Avatar
jwtaylor
From what I have been told it is not a good idea, you should use a hydraullic cam with hydraulic lifters and solid cam with solid lifter as the cam is designed for each lifter design. Later
Old Oct 19, 2003 | 10:46 PM
borin&strokin's Avatar
borin&strokin
NO! There is no ramp to take up the slack in the lash, and you CANNOT run solid lifters without lash. If you ran solid lifters on a hyd. cam, I would be VERY surprised if it survived the breakin period.
Old Oct 20, 2003 | 08:57 AM
460Ranger's Avatar
460Ranger
I talked to CompCams and my cam shop down the street from where I live and they both said you can use solids on a hydraulic cam. As with all solids you need ajustable rockers, should be ok, but I've not tried it yet.
