code P2290
Old Jun 1, 2012 | 07:15 PM
BLADE35's Avatar
BLADE35
Originally Posted by DFLS
Thanks again --- I'll do what I can and report back.
Ya IPR is pretty much a POS on any model under turbo and need a special socket to get it out
study that link to 6.0L Bible TONS of good stuff there
Old Jun 2, 2012 | 12:30 AM
DFLS's Avatar
DFLS
Would the "special" socket just be the head of 3/8" or 1/4" socket wrench or an extension? (just looking at the picture it looks like a square hole)
And upon removal will there will be a screen in the IPR itself or in the hole it came out of?
Old Jun 2, 2012 | 01:01 AM
BLADE35's Avatar
BLADE35
Would the "special" socket just be the head of 3/8" or 1/4" socket wrench or an extension? (just looking at the picture it looks like a square hole)?
NO^^^^^^^^^^
There a couple Types one is a Socket that has a slot in it some get deep socket and cut a slot in it
Or a Crows foot type wrench
Either a 36mm or 1 3/8 socket/crowfoot
Yes either or
Old Jun 2, 2012 | 07:37 PM
DFLS's Avatar
DFLS
I just ordered an EGR delete kit from Custom Diesel and will check the IPR screen when installing the kit. I see now where a socket with a section cut out will be needed. Would now be the time to go to a 4" turbo back exhaust?
Also, the screen on the IPR -- is that replaceable or do I have to replace the whole IPR?
My ICP is on the passenger side valve cover, easy to access.
Old Jun 3, 2012 | 12:53 AM
BLADE35's Avatar
BLADE35
I just ordered an EGR delete kit from Custom Diesel and will check the IPR screen when installing the kit. I see now where a socket with a section cut out will be needed. Would now be the time to go to a 4" turbo back exhaust? .
You could swap to 4in turboback whenever
Depends what you find when you pull IPR Out
Yes they sell just a screen kit for IPR IIRC
But if you find IPR with a Damaged screen Like a Hole in screen or it looks pushed up in the IPR a little you will need the whole IPR Valve. An air test might point you in a diffrent direction IDK
With the DTC you have being HPO Problem might be worth putting a new IPR in
BM88
6.4L Power Stroke Diesel
Jan 29, 2017 07:39 PM
TheWhiteBeast
Jan 24, 2012 09:42 PM
sierrason
1997 - 2003 F150
Nov 22, 2009 02:49 PM
daw1264
1997 - 2003 F150
Feb 7, 2002 07:30 PM
