I just ordered an EGR delete kit from Custom Diesel and will check the IPR screen when installing the kit. I see now where a socket with a section cut out will be needed. Would now be the time to go to a 4" turbo back exhaust?
Also, the screen on the IPR -- is that replaceable or do I have to replace the whole IPR?
My ICP is on the passenger side valve cover, easy to access.
I just ordered an EGR delete kit from Custom Diesel and will check the IPR screen when installing the kit. I see now where a socket with a section cut out will be needed. Would now be the time to go to a 4" turbo back exhaust? .
You could swap to 4in turboback whenever
Depends what you find when you pull IPR Out
Yes they sell just a screen kit for IPR IIRC
But if you find IPR with a Damaged screen Like a Hole in screen or it looks pushed up in the IPR a little you will need the whole IPR Valve. An air test might point you in a diffrent direction IDK
With the DTC you have being HPO Problem might be worth putting a new IPR in
