Rewiring questions
Old May 29, 2012 | 05:05 PM
Rhinoh22's Avatar
Rhinoh22
Rewiring questions
So I have installed a 12v starter relay/solenoid in my 54 F100. All the original wiring is gone and I am installing new wiring, I'm in the process of ignition wiring and need to know if my 'I' side of relay and coil + need to be dropped from full batt voltage? I have direct wires ran now but can install inline resistors if need be.
The truck was originally 239 OHV V8 but now has a 1960 292 in its place with all 12v coil, generator, etc.
Old May 29, 2012 | 06:13 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
A typical points style distributor will have a ballast resistor in the ignition wiring. There is typically 2 circuits from the ignition switch; 1 that will supply 12V to the ignition when the key is in the "crank" position, and another that is routed through a ballast resistor dropping the voltage approx in half when the key is in the "run" position.
Good luck
Bobby
Old May 29, 2012 | 06:15 PM
f5fordgirl's Avatar
f5fordgirl
The I wire from the soleniod to the coil remains 12 volt, if you used a coil that says, use with external resister, then yeah, you need one between it and the switch. If the coil says, use without external resister, then no resister is needed.
Old May 29, 2012 | 07:24 PM
Rhinoh22's Avatar
Rhinoh22
It appears to be the stock type coil from the 60 292, has no resistor but unsure if missing one, all wiring is replaced so any factory inline ballasts, etc are gone, haven't found which points in the system should be full voltage and which should be reduced.
Old May 29, 2012 | 09:25 PM
f5fordgirl's Avatar
f5fordgirl
If you're going to use your 54 gauges then only need 6 volts, same with heater and wiper motor, all lights can be changed to 12 volt bulbes.
Maj spoons
38
Oct 11, 2017 06:23 AM
first rebuild
Feb 20, 2011 02:49 PM
Boo-Boo
May 6, 2010 08:49 PM
TFagerholm
17
Jun 8, 2009 05:26 PM
volleyball33
Electrical Systems/Wiring
Jun 5, 2002 09:21 PM
