transmission help
Old May 29, 2012 | 11:00 AM
deersticker's Avatar
deersticker
transmission help
i have a 03 x 6.0 the problum i had is temp gage drop to 0 and then went as hot as it could then my tow/haul started blinking.so i was close to home and just parked it.could it be a bad stat?do i have a 4r100 or5r110w? thanks fo any help.
Old May 29, 2012 | 03:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You have a TorqShift transmission, also known as the 5R110. Your trans has a bad Transmission Fluid Temperature (TFT) sensor. It is inside the pan and not that hard to change. A new one is under $20 at any Ford dealer.
Old May 30, 2012 | 09:14 AM
deersticker
Thank you so much Mark.I knew you guys on this site could help.Once again thanks.
hanklin
Jun 26, 2017 03:28 AM
Sarge261
6.4L Power Stroke Diesel
Sep 13, 2016 06:20 PM
JAYSF350
Nov 17, 2009 09:19 PM
Javier.M
Dec 23, 2007 06:41 PM
dieselfitter
Dec 5, 2006 04:07 PM
