ECT ~210-220f while towing 4k# TT
Old May 28, 2012 | 09:10 PM
k4rd's Avatar
k4rd
Just got back from a weekend camping trip out to Hagerstown MD and in the process climbed over a few rolling hills on I-70. I have mounted pillar gauges to monitor the ECT (mounted in engine block) and Trans temps. While climing the grades my ECT would climb to 220f the rest of the time even on flat interstate it would stay at ~210f over all trip was about 3 hours. From reading other post I have seen that 220 should be the alarm temp. My degas bottle has fluid in it at the correct level. How concerned should I be with these temps and what should I be looking for? I just got AE with the Ford bundle the day before I left for my trip and was able to check my delta between ECT and EOT and it was only ~7 degrees different. My normal driving temp with no load is about 195. I bought the truck used a few months ago with 80k miles and it appears to be in good condition, I do know from an OASIS report that it had the EGR cooler replaced at 60k miles.
Old May 28, 2012 | 09:33 PM
steelhead2's Avatar
steelhead2
Did you hear the fan come on?. At 220 Youll hear it.
Old May 29, 2012 | 09:22 AM
j4henry's Avatar
j4henry
I just drove 700 miles pulling 7600 lb TT and my ECT stayed around 210-220 but my delta stayed within 15* as long as fan kicks in you should be fine
Old May 29, 2012 | 01:49 PM
Forest's Avatar
Forest
I just pulled 10K tall travel trailer back from Kansas into a 15 mph headwind at 65 mph. Saw 215F several times on ECT, but fan would kick in and knock it down. My EOT (engine oil temp) never exceeded 221F.
Old May 29, 2012 | 08:45 PM
k4rd's Avatar
k4rd
Thanks for the replys. I knew my TT wasnt all that heavy I just worried after seeing those temps but I guess it is normal from what you guys are all saying.
Yoteman
Jul 14, 2024 01:35 PM
HRobertson1
Apr 30, 2020 11:31 PM
tracyclifton
Mar 5, 2015 08:05 AM
mgood
Feb 28, 2012 05:28 PM
gumbyone
Jul 17, 2008 12:23 AM
