2000 psd batteries draining overnight
Old May 27, 2012 | 12:28 PM
UNTAMND's Avatar
UNTAMND
My batteries are 2 years old and alt checks out fine.
Why is my truck draining the batteries.
Glow plug relay isn't stuck on so it's not that.
What else can I check
Old May 27, 2012 | 12:55 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Get a volt meter and check every fuse one at a time.
Old May 27, 2012 | 07:49 PM
c125bob's Avatar
c125bob
Good advice, and..... feel your alternator first thing in the morning while everything is cool. Is it warm to touch?
Old Jun 20, 2012 | 06:47 PM
dbass880's Avatar
dbass880
Same problem here.
I am having the same problem. I just got brand new batteries about 2 months ago. I have recently put in an aftermarket stereo and a backup camera. I feel like one of those is the culprit. I checked each of the fuses with a voltmeter. I may not have been doing it right though.
I disconnected both neg. cables then touched the voltmeter to the battery post and the cable. Is that the correct way?
Old Jun 20, 2012 | 07:53 PM
landmobile's Avatar
landmobile
The way you have the meter connected is correct, just make sure it is set to read amps, not volts, and plug the probe into the correct jack on the meter. You want to read the current (amps) being drawn from the batteries, not the voltage. Current draw with doors closed and everything off should be less than .05 amps. If there is excessive draw you can remove fuses individually to isolate the source.
Chris
Old Jun 20, 2012 | 08:25 PM
dbass880's Avatar
dbass880
around .2
Well I had it connected correctly. I'm getting a .2 on the draw. I guess that is enought to drain the batteries overnight? It really doesn't have to be overnight. 4-5 hours will drain them.
Thanks for that quick reply.
Old Jun 20, 2012 | 08:38 PM
landmobile's Avatar
landmobile
0.2A is high, but it sholudn't drain your batteries in a few hours. I would have each battery individually load tested first. You might have a weak battery discharging the good one.
Chris
Old Jun 20, 2012 | 08:53 PM
dbass880's Avatar
dbass880
Ok. I'll give that a whirl. I just replaced them both but I guess I could've gotten a bad one. Thanks.
Old Jun 20, 2012 | 08:58 PM
landmobile's Avatar
landmobile
If both batteries check good and they are going dead in a few hours with only 0.2A draw, then the next step will be to check the charging system.
Chris
Old Jun 20, 2012 | 09:07 PM
dbass880's Avatar
dbass880
They get fully charged so I think that is ok.
Old Jun 20, 2012 | 10:01 PM
Bonanza35's Avatar
Bonanza35
Sometime the diode in the alternator goes bad and drains the system. But if you just installed new equipment and thats when it started, thats probably where it is.
Chet
Old Jun 20, 2012 | 10:07 PM
dbass880's Avatar
dbass880
Do you just test the alternator to check that problem?
Old Jun 20, 2012 | 11:20 PM
Bonanza35's Avatar
Bonanza35
I think it has to be bench tested. But like said above, feel it in the morning to see if its warm.
Chet
wicked_richard
Sep 6, 2011 07:55 PM
Nader
Feb 23, 2011 04:00 PM
charon61285
Feb 23, 2011 12:31 PM
Big Z
Oct 5, 2009 08:46 PM
///00dually
Nov 20, 2007 04:49 PM
