P0209 Injector 9 Control Circuit...help please.
Old May 26, 2012 | 07:19 PM
f150crewcab's Avatar
f150crewcab
My new (to me) 2005 X just threw the P0209 code (per my ScanGauge II). I found another post that says its the Injector 9 Control Circuit. Where is this located and can a shade-tree mechanic (me) fix it? Are there other things I should check that could have caused this failure (like wiring chafing)? Thanks for the help.
6.0L PSD with 116K miles.
Old May 26, 2012 | 09:41 PM
m-chan68's Avatar
m-chan68
Ummm, last time I checked every 6.0L I've ever worked on, only has eight cylinders.
Old May 26, 2012 | 10:05 PM
f150crewcab
That's what I thought...hence my quandary. Nevertheless, P0209 is what is showing on my SGII. Doing some more looking. Any help appreciated.
Old May 26, 2012 | 10:21 PM
KRDiesel's Avatar
KRDiesel
I would take it to autozone, or see if a friend has a scan tool and recheck the code
Old May 26, 2012 | 11:06 PM
zhilton's Avatar
zhilton
Sounds like wire chaffing to me. Is there a "reset" option for the SGII? Maybe I need to get one of those to keep in the truck...and leave the AE in the toolbox. That way I'll have experience with an SGII.
Old May 26, 2012 | 11:13 PM
BLADE35's Avatar
BLADE35
Yes you can reset SGII back to manufacture settings
Are you shure the DTC is not a P0299?????
I beleive the DTC P0209 is for a V-10
Old May 27, 2012 | 01:45 PM
f150crewcab
Actually, I was drifting to sleep last night wondering if I muffed the code (duh!!). I think it actually is P0299, which implies a sticking turbo (at least that what I can surmise). I cleared the code with my SGII and drove it hard from a few stop lights (20+ lbs of boost) to try and clear out the soot.
Another thread suggested Racor Diesel Conditioner Plus. Any thoughts?
Thanks again.
Old May 27, 2012 | 02:09 PM
BLADE35's Avatar
BLADE35
Well thats what I thought
I doubt fuel additive gona help fix now
Fuel additive is Great for preventative Measure but your to the problem stage
what kinda Boost psi do you see High psi or Low psi
Old May 29, 2012 | 11:05 AM
f150crewcab
Being a PSD newbie, are you referring to fuel pressure psi? I haven't yet set up my SGII to monitor fuel pressure. When I stomp on the accelerator from stop, I do see boost in the mid 20's, however.
I reset the DTC via the SGII and the CEL has remained off. I will be pulling my 8000# camper this weekend but want to make sure I don't do any more damage. Thanks.
Old May 29, 2012 | 11:25 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
SGII doesn't do fuel pressure.
Have you set up an Xgauge:
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
Counts trouble code cycles. Ones that are there, yet not showing a light as of yet. (not enough cycles to throw the light on) Kind of gives a heads up.
I had mine show a count and found it was a fan speed sensor issue. My SGII can't read those "pending codes". I thought newer updates can, not positive though.
Old May 29, 2012 | 09:49 PM
zhilton's Avatar
zhilton
The only way you can monitor fuel pressure is to plumb a sensor into the test port of the fuel pressure regulator.'You'll need a M12x1.5 metric fitting to thread into that port. Folks like Clay at RiffRaff carry an adapter that will convert it from metric to 1/8 NPT. This is the gauge I'm running in my truck:
Riffraff Diesel: Fuel Pressure 0-100 PSI
And it's mounted in a 3-gauge A-pillar pod that I also picked up from Clay. He'll pre-paint them if you supply the trim code of your truck. When you install one, just remember that the fuel pressure should never get below 45psi when the engine is running. Above 60psi is where you want to be.
Old May 30, 2012 | 08:18 AM
f150crewcab
I did pay more attention to my boost yesterday and noted 22.8 psi under heavy acceleration. Good, right?
Also, I set my SGII Xgauge to monitor the DTC as amdriven2live suggested. Only 1 DTC (presumably the P0299 code previously mentioned).
So.....given that the P0299 code flashed once, is there anything preventive I can do to help clean the turbo short of pulling it out (i.e. additives)?
Regarding fuel pressure, I wrongly assumed that the ICP (injector control pressure) in my SGII Xgauge would provide me the same reading as fuel pressure...Not! Thanks zhilton for the post...great detail. Regardless, I'm going to do the Blue Spring upgrade to insure proper fuel pressure.
zhilton: curious, what other gauges do you run? I been noting other's preferences including ECT, EOT and transmission. Thanks.
Old May 30, 2012 | 11:27 AM
amdriven2liv
Your SGII will do those three. (ECT,EOT, Trans) Try fuel pressure (as stated above) and EGT's. The third? That's the question.
Old May 30, 2012 | 03:59 PM
zhilton's Avatar
zhilton
Fuel pressure, boost and pryometer are in the A-pillar of my truck.
KC8QVO
6.7L Power Stroke Diesel
Nov 5, 2018 05:23 AM
mrc00l88
May 10, 2016 10:04 AM
elyrain
Jan 10, 2015 05:40 PM
BD75
18
Aug 11, 2014 03:55 PM
David7.3
Jul 8, 2014 07:04 AM
