Sponsored by: Auxito
Odd shifting problem?
Old May 26, 2012 | 03:35 AM
fun_on_road_daily's Avatar
fun_on_road_daily
In my 1998 f150 4.6L 5 speed manual. When I go to put it in reverse I get 1st instead, but if I do a second shift to reverse I get reverse. This happens on an average of once a week.
I know this can happen in FWD cars where you put it in one gear and get a different gear instead. Something to do with the shifting cable. But the f150 is RWD, the shifting problem only happens in reverse. Is this problem someone without ASE certificates can do, or without dropping the transmission?
I'll add to this so I dont start yet another post. Ive thought of the problem and if it was really going into 1st instead of reverse the problem likely would be bad egnough it would just stay in 1st. Its possible that Iam getting 4th gear when I go into reverse which tells me the clutch grabs really well, and its a problem I really need to fix, I dont know that much about transmissions but I do know if it keeps getting 4th instead of reverse, the clutch wont be so good pretty fast.
Old Sep 15, 2012 | 01:57 AM
fun_on_road_daily
Just thought I would give an update, the problem strange egnough turned out to be the pilot bearing, while I thought it was rolling forward, it was just coasting and not really going into reverse. If I turned the engine off it would then go into reverse. It finally got to where you had to shut the engine off everytime you stopped 1st or reverse. So after having the clutch & pilot bearing replaced all is good for now.
mtsnieg
Nov 20, 2023 09:56 AM
f350rebel7788
24
Nov 19, 2021 09:43 PM
Wild-Bill
Dec 12, 2013 05:56 AM
Neal 97 250
Oct 12, 2008 10:48 AM
Country705
Feb 11, 2007 08:45 AM
