Fuel issue...I think!
Old May 25, 2012 | 05:03 PM
brpayne17's Avatar
brpayne17
I'm sorry if this issue has been posted before. I have looked around through the forum and have not seen anything with the exact issues I have.
I have a 86 f150 efi 302 auto with the c6 trans that will start and then die 30 secs to a minute later, then it will turn over and struggle, but it will remain running. This only happens in the morning and when I leave work for home in the evenings. While driving it just feels like it needs more power. It feels like there is a lag between pressing the pedal and the truck going forward. I had taken it to a shop and they performed the diagnostics and said the fuel pressure was fine.
Recently I have put in a new rear gas tank with fuel pump, sending unit, plugs, wires, cap, fuel filter, IAC, water pump, belts, hoses, air filter. I changed tranny filter and fluid and oilf filter and oil. I have used fuel injector cleaner a coulple of times as well. Any help would be appreciated....
I do not have a lot of experience but am handy with a wrench. I can figure most things out when pointed in the right direction. I also have a can of the seafom but was not sure if it would be good to use right now.
Old May 25, 2012 | 05:55 PM
ctubutis's Avatar
ctubutis
On a computer-controlled engine, I would ask the computer what it thinks is happening.
Here's how:
Fuel Injection Technical Library » How To Run a Self-Test
Old May 25, 2012 | 06:26 PM
brpayne17's Avatar
brpayne17
Sorry..I forgot to mention that I did take it to Oriell'y and they ran the codes and came up with 31. I believe it has something to do with egr. However the kid who did it didnt seem like he knew what he was doing and I kind of got fed up with it and left. I will have to try a different place or try the self test. Thanks for the reply.
Old May 25, 2012 | 06:31 PM
ctubutis's Avatar
ctubutis
An EGR valve that's stuck open will result in a crappy idle and could even cause the engine to die (at idle).
Read that site, you can pull codes at home by jumpering one wire to a ground and counting blinkenlights.
Old May 25, 2012 | 06:59 PM
brpayne17's Avatar
brpayne17
Thanks... will do tonight and let you know.
Old May 25, 2012 | 09:44 PM
JayzDaddy's Avatar
JayzDaddy
Any chance of a clogged filter. Seem to recall a 69 C10 chevy actin similar.
Old May 26, 2012 | 07:59 AM
klricks's Avatar
klricks
My book says code 31 = (Trucks Only) EVAP control system below minimum voltage
The code 31 = EGR is for trucks without V8 engines.
I also made a code reading tutorial... link in my signature.
Old May 26, 2012 | 09:13 AM
brpayne17's Avatar
brpayne17
I appreciate the responses..... I had to go out of town on emergency business so I will have to wait till I get back to try the self test and check the evap voltage. Once again thanks for the replies. I will post results next week and see where we can go from there.... Hope you all have a good memorial day weekend!
bozo4ford
1983 - 2012 Ranger & B-Series
41
Sep 2, 2014 06:04 PM
allen23923
Jan 25, 2012 08:41 AM
weldworks54
Sep 11, 2011 09:45 AM
msgntsu
Apr 25, 2006 01:56 PM
MAJORMUNCHIE
Aug 28, 2002 04:01 AM
