maybe u jus got a turbo tats going out. if ur gonna replace the turbo, i'd recommend the powermax turbo. i've looked at the specs and i have a fren who actually has one of these on his bad boy. it runs like a beast and it's more reliable than our stock ones.
seems like u picked out a egr cooler & oil cooler package. if tats the replacements and the real prob, then wat caused it to die in the first place? did u have the green coolant in there? i hope not. did u add any other additives to ur coolant? i hope not too.
yes, benny is right about the EBP psi. i tink, if i'm not wrong, if it's out of whack, then it's best to just replace the sensor, right?
if ur IC tubes & cac tube are dirty as hell, maybe a chemical bath might make them feel better and perform better too. lol.
from the sound of tat p2263 dtc, it sounds like a couple of things. maf sensor dirty or faulty. or turbo is defective and finally gonna give out.
sorry, so far my brain could only come up with these possible scenarios. hungry. going for dinner now.
i just noticed. u mentioned edge insight cts? have u tried running ur truck with it unplugged to see if tats the cause of ur turbo prob? u know electronics..... they all act screwy sometimes..... lol.
if u run ur truck without the edge insight cts, and u dont have a prob, then tat thing would be ur prob. i tink i talked to someone who had a prob with his edge thingey. he took it off, and it ran good. i tink he also took his tune off. u mentioned "level 2". is tat a tune i hear u running? lol. it could also be the tune tats messing ur car up too.
dont shoot me down. i'm jus the snuggyworm. jus throwing out ideas and trying to cover all the bases. again, i could be wrong. i'm not always right, but like everybody else here, we'll do our best to help u.
Got to Cover all the BASES you never know what will go wrong
