Ignition issue
Old May 23, 2012 | 06:00 PM
Locorotc's Avatar
Locorotc
Ignition issue
Hello all,
Recently bought a 1988 F150 Lariat xlt with 55000 miles on it. Ran into an issue with the ignition. The truck will start just fine, however when i go to shut it off, nothing. The truck stays running. I replaced the ignition box on the column and its still doing it, please please please help, im in the Army and need this vehicle and I am getting tired of shutting it off using the fuel pump solenoid. Also a brand new fuel pump solenoid was placed in it.
Old May 24, 2012 | 12:33 PM
Locorotc's Avatar
Locorotc
Please somebody help, need to fix this and I can't figure it out.
Old May 24, 2012 | 02:04 PM
Fungus232's Avatar
Fungus232
Did you replace the tumbler (the actual ignition switch the key goes in)?
Old May 24, 2012 | 02:32 PM
Locorotc's Avatar
Locorotc
No I have not, would that cause it? Of have some kind of effect on it?
Old May 24, 2012 | 04:23 PM
F150xlt's Avatar
F150xlt
Has the ignition switch ever worked properly since you've owned the truck?
If not, Bubba may have did some wiring modifications.
The ignition switch is bolted to the middle of the steering column.
When you turn the ignition key, the key cylinder operates the
actuator which is made of pot metal. Attached to the actuator
is a rod. The other end of the rod attaches to the ignition switch and
is what moves the ignition switch to 5 positions.
You should only be able to remove the ignition key when the key cylinder is in
the Lock position.
Lock (insert or remove the ignition key in this position steering wheel is in locked position).
Off (key can not be removed engine should shut off, dash idiot lights off).
Run (Normal position with engine running, dash idiot lights on if engine is
not running).
Start (Starter cranks the engine) this position is spring loaded when
released it goes to the Run position.
Accessories (all the way counter clockwise. Radio should work in
this position).
Do you have all 5 positions?
The ignition switch has slotted mounting ears and can be moved
up and down the steering column until you get all 5 positions.
Do you have the tilt wheel option?
It's operated by pushing the turn signal lever back towards the dash.
If you have tilt wheel, move the steering wheel all the way up or down
and see if the engine can be shut off.
Old May 24, 2012 | 06:09 PM
tjc transport's Avatar
tjc transport
i ain't rite
search ignition actuator. it is in the top of the column under the steering wheel. it connects the key cylinder to the ignition switch rod.
99% of the time it breaks in a no start position. 1% of the time it will brake in a no shut off position. the part costs around $15, and takes a few hours to change.
Old May 24, 2012 | 07:52 PM
Locorotc's Avatar
Locorotc
Ok gentlemen, I have had the truck for a couple of weeks now, when I bought the truck, it did shut off with the key now nothing.
Old May 24, 2012 | 07:57 PM
White 97 xlt's Avatar
White 97 xlt
I second this !!!!
Old May 24, 2012 | 11:48 PM
HD's Avatar
HD
Locorotc,
This is all awesome info these guys are posting up. My question is: How does the ignition lock cylinder feel when turning it? Has the resistance changed? Lost it's, uh, springiness? Have you tried moving just the rod itself and see what happens?
There is a procedure for adjusting the ignition switch. If you need it I will try finding it for you. As long as the actuator they mentioned earlier isnt broke, then the other component that is a key player is the gear that resides behind the lock cylinder that you turn. If it is not installed properly, it will rob you of key positions. Even one tooth off will jack it up. Good luck to you!
Chris
Old May 25, 2012 | 08:47 AM
Locorotc's Avatar
Locorotc
Thank you gentlemen, I haven't recently tried to remove the ignition switch on the column but when I did, I forgot that I left the key in the on position so would the vehicle turn off if you left the key on?
Old May 25, 2012 | 03:47 PM
Locorotc's Avatar
Locorotc
If the ignition tumbler were to go bad, would that cause it to not shutoff but let it start?
Old May 25, 2012 | 04:11 PM
tjc transport
i ain't rite
no. the key cylinder either works, or don't.
Michael Mccormick
1997 - 2003 F150
Apr 28, 2019 06:59 PM
Silvestris
Apr 8, 2013 12:38 AM
carolinaranger90
May 27, 2012 11:50 AM
higdogg
Dec 21, 2006 12:30 AM
jmgodshall
Electrical Systems/Wiring
May 13, 2006 09:08 AM
