Ignition problem, please help!
Old Apr 7, 2013 | 07:16 PM
Silvestris's Avatar
Silvestris
So, I have a 1995 F-150 5.0 that has been sitting for about a week while me and a buddy did the clutch. We're almost done, my buddy says he gets in and rips the key out of the ignition on accident. We get done, I go to back out, I move about 50 feet and the starter randomly engages. I hurry up and turn the ignition off, take the key out, and it's still running. No matter what position the key is in the truck won't turn off. I have to stall the motor to get it to turn off and even then all my accecories and stuff are still on. I replaced the ignition lock and didn't help anything. Starter still cranks over properly although if the key gets too close to the start position while in run, it'll engage. Anyone know wha'ts going on and how to fix the thing? Kinda pissed that I fixed my truck and it breaks right when I get done.
Old Apr 8, 2013 | 12:38 AM
MeanGreen460's Avatar
MeanGreen460
Check out your ignition switch There is a rod from your tumblers where your key goes in running down side of steering column that goes to the ignition switch .may be out of adjustment something broken? .you got to pull the plastic cover around steering column to see ignition switch .You may end up replacing your ignition switch
quakerj
Nov 3, 2017 08:04 PM
TJS96F-150
16
Jan 1, 2008 04:49 PM
jmgodshall
Electrical Systems/Wiring
May 13, 2006 09:08 AM
pmibach
1978 - 1996 Big Bronco
Jan 31, 2006 08:37 PM
JSS
Jan 2, 2003 08:31 PM
