ignition issue
Old May 12, 2006 | 10:58 AM
jmgodshall's Avatar
jmgodshall
ignition issue
I got an oldie but goodie, 1986 ranger with 156,000 4cyl, 5speed. I have to hold the key forward inthe ignition to keep the truck running. i replaced the ignition and key on the steering column but the new ignition key still has to be held forward to keep it runningjmgodshall@excite.com
Old May 12, 2006 | 09:59 PM
Franklin2's Avatar
Franklin2
Take the upper and lower halves off the column and find the ignition switch. See if the key is moving the switch enough. Make sure the switch is also adjusted correctly. You may be able to slide it up enough to fix the problem, or there may be a mechanical problem with the actuator rod.
Old May 13, 2006 | 09:08 AM
jmgodshall's Avatar
jmgodshall
Thank you
jmgodshall
67F250RET
Sep 4, 2024 12:10 PM
blake8105
WTB - Parts & other
Sep 23, 2016 10:44 PM
rswhitmore
Aug 11, 2016 07:58 PM
zach3713
May 23, 2015 08:55 PM
VolvoMatt
Oct 9, 2013 11:43 AM
