Larger Fuel Tank Availability.....
Old May 22, 2012 | 04:20 PM
Diesel_Brad's Avatar
Diesel_Brad
Yes the F26E is the common swap for the rear tank for more capacity. You just need to bend your sending unit float so it will reach the bottom of the tank or your gauge will read empty too soon
Old May 22, 2012 | 04:40 PM
62FE4x4's Avatar
62FE4x4
Thanks Brad,
I think I am going to go with that tank and the doorman sending unit that matches it. I was confused as to why it said this tank would only only work with 87-89 Fseries. According. To Ford 90 was an an engineering change that added a vented hose. Since my truck has a 6 inch left I think I can do away with that flattened house anyway. I can't foresee any other problems it would have since it would bolt right in.
Old May 22, 2012 | 05:19 PM
Twistedwrench's Avatar
Twistedwrench
The only truck(s) these large capacity tanks won't work in are the cab as chassis - with the rear plastic tank and skid plate / strap assembly . ( which sucks ! I have 2 service truck!) since you have a 1990 diesel I'd say to use a modified 1987-1989 sender . Since you don't need the intank lift pump you can remove that and the connectors on the sender .
Old May 22, 2012 | 07:35 PM
62FE4x4's Avatar
62FE4x4
I agree. I tale to the people at Doorman that makes the sending unit and they said there wasn't a pump on that unit so it should work well. I am going to replace the flattened hose with the regular hose so I won't take an hour filling it up at the pumps. Thanks for all the input.
1972fordhighboy2
Sep 15, 2018 05:57 PM
jimjoebob99
Sep 14, 2011 01:59 PM
StillaKilla187
1978 - 1996 Big Bronco
Jan 20, 2008 09:41 PM
baddb2owner
Bronco II
Mar 19, 2006 09:11 PM
dogerbrown1
Dec 6, 2002 03:38 PM
