Larger Fuel Tank Availability.....
Old May 21, 2012 | 10:25 PM
62FE4x4's Avatar
62FE4x4
I just got my 1990 F350 4x4 on the road after a lot of little things wrong like injector pump being bad, charging system not charging, etc. Fuel mileage is right with my Powerstroke. However a guy was telling me there is a certain model Bronco rear fuel Tank & sending unit you can get that will bolt right to my frame. Any idea which year would work? I am assuming around a 1983 Bronco? Thanks. Any and all input appreciated.
Old May 21, 2012 | 11:11 PM
XLT89F350cc's Avatar
XLT89F350cc
1990 33g bronco tank
Old May 21, 2012 | 11:16 PM
62FE4x4's Avatar
62FE4x4
Are you sure? I was told it would have to be 1984 or older because a fuel injected sending unit would not work with a 1990 idi?
Old May 21, 2012 | 11:47 PM
XLT89F350cc
not sure about that. Go look into a 38 g from 88 F series or F Superduty, uses your stock sender an pump
Old May 21, 2012 | 11:49 PM
62FE4x4's Avatar
62FE4x4
Pump mounts on engine on idi. Sensing unit I need to bw accurate with my gauge. I just want to be sure I get the right one. I also need to be able to use my Hitch. Is the 88 Bronco a 38 gallon?
Old May 22, 2012 | 12:56 AM
XLT89F350cc
broncos are 25 and 33's
F series rear tanks are 18,19 and 38's
the diesel forums may know better
Old May 22, 2012 | 01:00 AM
62FE4x4's Avatar
62FE4x4
99 & later midframe tanks are 38. I need an after axle tank with a rear sending unit that will work right with my truck. This is supposedly a common conversation. Has nobody here down this with their F350 trucks? I am looking for facts; not guesses and assumptions. Thanks
Old May 22, 2012 | 01:09 AM
XLT89F350cc
99 and 90 trucks are 2 different things. Bronco tanks are REAR tanks NOT midframe tanks. SO, i'm not guessing or assuming. You posted about a 90 F 350, i'm telling you about 86-96 trucks.
Do you know what a 99 truck looks like ?
Old May 22, 2012 | 01:18 AM
62FE4x4's Avatar
62FE4x4
If you want to be sarcastic post somewhere else. I did not bring a 38 gallon into the conversation. I merely stated 38 gallon tanks are 99 and later Super Duty trucks. I know Bronco tanks are after-axle tanks for 1978 and later Bronco. Yes I know what a 99 and newer Super Duty is. I have one. I build these trucks for a living. Once again if you can't be helpful stay off my post. I know a 90 Bronco tank will be compatible with my frame. I am trying to make sure the sending unit is also compatible with my truck from a 90 Bronco. I think I would need a pre1985 sending unit. This is what I need input about.
Old May 22, 2012 | 01:26 AM
XLT89F350cc
38's are listed for 86-89 F series. And if you build these trucks for a living, you should know this. And your stock sending unit works with a 38g tank.
Old May 22, 2012 | 01:29 AM
XLT89F350cc
rock auto dot com
88 F350 460
SPECTRA PREMIUM Part # F26E More Information About this Part Lock Ring Kit Included One of our most popular parts
[Flag indicates this part fits vehicles sold in the US Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide.] [Flag indicates this part fits vehicles sold in the Canadian Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide.]
38 Gallon; Behind Rear Axle; 34-3/4" x 27" x 13-3/4"; Optional High Capacity Tank; Requires Modification of Sending Unit as per Instructions in Box
Part Image
Choose:
$157.79
Add Part
DORMAN Part # 576167 More Information About this Part {#E7TZ9002A} Dimensions: 27" x 34-1/4" x 13-3/4"; Gallons: 38; Liters: 144; Lock Ring #: LO04, LO26D
[Flag indicates this part fits vehicles sold in the US Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide.] [Flag indicates this part fits vehicles sold in the Canadian Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide.] Rear Mount; 38 Gallon
Guess i dont know what i'm talking about
Old May 22, 2012 | 01:52 AM
62FE4x4's Avatar
62FE4x4
Yes I build these for a living. We did not build a 87-91 F150-350 with a 38 gallon tank. The cab chassis model had a bigger fuel tank, but it was the Heavy Duty series with the longer frames and the linger wheel base. I buy a lot of after market parts from Rock Auto. If you have information I welcome it. However when you act like a jackass you can keep your information. I don't the attitude.
Old May 22, 2012 | 03:14 AM
XLT89F350cc
well i wasnt guessing or assuming anything. I told you exactly what i knew
Old May 22, 2012 | 12:23 PM
big vann's Avatar
big vann
The same year (as your truck) Bronco tank will fit in your truck.Make sure you know the dia. of the sending unit opening and get the pick-up to match.I did this on my '88 f250 to eliminate the side tank for true dual exhaust.Bronco Graveyard sells a 33 gal polyethelene tank for a little more than a steel tank.They also have the matching sending units(one from a 1990).Had one on my Bronco for 9 years without issues,very durable.Sold the Bronco.I had a four prong connector on my sending unit for the '88.
Old May 22, 2012 | 02:41 PM
62FE4x4's Avatar
62FE4x4
This 38 gallon tank from Rock Auto looks like it will work. It has the right dimensions for my frame. I just hope it isn't so deep I have hitch issues. My truck is a 1990 F350 crew cab idi, and we were able to run 3" true duals with one chamber flow masters and stainless tips. We had plenty of room to leave the midship tank in as well.
