1978 - 1996 Big Bronco
Drop Gas tank
Old Jan 9, 2008 | 10:19 AM
StillaKilla187's Avatar
StillaKilla187
Drop Gas tank
Theres a rust hole in near top of my gas tank, in my 1995 bronco 5.8L auto. i have the 33 gallon, what is the size of the fuel sending unit hole? and how hard is it to drop the tank? Im pretty sure im replacing it with a plastic tank so it doesnt happen again.
Old Jan 9, 2008 | 10:45 AM
Kemicalburns's Avatar
Kemicalburns
just go to ford and get a replacment fuel pump and be sure to buy a tank for your year bronco. not a big deal
Old Jan 9, 2008 | 10:52 AM
StillaKilla187
Well, the fuel pump is fine, i just need a new tank. and there are like 4 different sizes of holes for the fuel sending unit. Thats the only problem, I have dropped tanks in other trucks its usually pretty straight foward, and easy. I was just seein how hard the bronco is.
Old Jan 9, 2008 | 12:29 PM
andym's Avatar
andym
Pretty easy to drop it from what I hear. No major trickery involved.
I think you misunderstood what kem was saying about the fuel pump. Go out and hold a fuel pump in your hands for your year and measure it so you know how big the opening is in your tank.
Old Jan 10, 2008 | 07:38 AM
StillaKilla187
ooooH that makes way more sense.
Old Jan 20, 2008 | 12:40 AM
Surge08's Avatar
Surge08
I just did my tank make sure you replace the upper straps. Mine had fallin apart when I removed the tank.
Old Jan 20, 2008 | 02:14 AM
khadma's Avatar
khadma
Carpenter Local 745
My tank is held in by the skidplate, and the bolts are the hardest items to deal with. Hit/spray them with a penetrating oil the day before and you will be okay.
Make sure you have an extra set of hands to handle the "empty" tank when you drop the tank from the bronc.
Old Jan 20, 2008 | 12:29 PM
Surge08's Avatar
Surge08
The skid plate is on the bottem yes. Above the tank is straps. you can't see them ontill the tank has been removed.
Old Jan 20, 2008 | 05:22 PM
khadma's Avatar
khadma
Carpenter Local 745
I know that, my uppers were okay. Getting the skidplate off is the toughest part of the job.
The bolts go through an insert that does not like the harsh under carriage elements. I can imagine how hard it is to break loose if the truck is in snow/ice/salt country.
The bolts have so much crud on them it takes some good torque to get off.
(1/2 drive tools or impact maybe needed).
Old Jan 20, 2008 | 08:36 PM
LCA078's Avatar
LCA078
I just dropped my tank on my '88 and it wasn't too bad of a job. Maybe an hour's worth of cursing but that's about it. 8 bolts (15mm nut and a 13mm bolt head), the fuel/electrical connections, plus the fill tube is really all it was. I pulled my tank pump and it looked like it dipped in asphalt. The tank is pretty nasty inside and I was wondering how much a new tank would cost. Any one have an idea? I was thinking of getting this one cleaned but I have no clue how close a hole is from rusting out on the inside and I don't think it's worth the chance.
Old Jan 20, 2008 | 08:42 PM
khadma's Avatar
khadma
Carpenter Local 745
Do some shopping too here's a start
http://www.car-stuff.com/store/?N=10337+4294966994+1616+11921+9296
Old Jan 20, 2008 | 09:41 PM
LCA078's Avatar
LCA078
khadma- Nice website for parts! Thanks for the heads up!
lmp5115
18
Sep 2, 2019 01:19 PM
deisele75
2004 - 2008 F150
Jul 15, 2012 08:28 PM
depotops
May 21, 2010 05:28 PM
drof46
Jul 18, 2009 07:42 AM
FLgargoyle
15
Apr 19, 2007 07:41 PM
