FIRST TOW UPDATE
Old May 21, 2012 | 07:24 AM
hoytfan99's Avatar
hoytfan99
FIRST TOW UPDATE
Towed again this weekend on flat highway pulling 7,000 lbs. Had eot 228 and ect of 207 give or take 1 or 2. I noticed after sitting all saturday and starting up sunday morning the eot was 11* Higher than the ect or tranny. Whats up.
Old May 21, 2012 | 07:50 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
Mayb a bad EOT sensor. IIRC it's only bout 40$ from ford dealer.
Old May 21, 2012 | 07:54 AM
WH 6.0's Avatar
WH 6.0
It sounds like you have a bad EOT sensor. Your temps. should be pretty much identical after a cold soak. I would replace the EOT sensor and check the deltas from there. IF the sensor is CONSISTANTLY 11 deg. off throughout the temp. range it looks like you would have a +/- 10 deg. delta which is good but the only way to know for sure is to get a new sensor installed.
Old May 21, 2012 | 04:14 PM
hoytfan99's Avatar
hoytfan99
thanks i kinda thought that after the cold soak numbers.
Alex1056
Aug 25, 2018 04:02 PM
W7PSK
6.7L Power Stroke Diesel
Jan 28, 2016 11:41 AM
daddykitty
Aug 2, 2014 04:40 PM
surfagoody
Dec 16, 2007 10:26 AM
99 Expy EB
Dec 26, 2006 09:50 AM
