Outside temp. sensor?
Old Dec 15, 2006 | 05:06 PM
99 Expy EB's Avatar
99 Expy EB
I think my outside temp sensor is bad. It says its -14 outside all the time.It does affect the ac and heat. It either too cold or too hot... Is there an outside sensor? Where is it? Do i need to replace to Climate controll? I hope its just the sensor.
Any help would be great.. Thanks Tony
Old Dec 17, 2006 | 05:04 PM
99 Expy EB's Avatar
99 Expy EB
No one has had this problem?
Anyone know where the sensor is?
Old Dec 17, 2006 | 05:34 PM
amm888's Avatar
amm888
on my pathfinder it's near the radiator, not sure where it's at on the expy
Old Dec 23, 2006 | 10:34 PM
99 Expy EB's Avatar
99 Expy EB
I guess im the only one that has ever had this problem
Old Dec 26, 2006 | 09:50 AM
italstallion2's Avatar
italstallion2
The temp senso is right behind the grill, you can see it. To get to it you have to take off the plastic cover under the hood. I thought mine was bad but I found out that if there is snow around it it can actually give you a false ready, also if there is dirt build up on it, it can give u a false reading. I hope this helps.
kingrl2
2009 - 2014 F150
16
Apr 24, 2021 10:31 PM
DavidE
28
Nov 14, 2016 03:42 PM
cutlass
Jun 13, 2012 11:18 PM
edgewound
Mar 11, 2007 10:28 AM
