my truck starts and goes in reverse but when i put it in drive it rattles and dies.i know very little about a trans.(almost nothing) i have a guy telling me that it sounds like a shift cylonoid sticking causing my problem. does anybody know about this? and what do i need if it is my problem?
It had 3 codes. I can't remember the numbers. They don't deal with the trans. 1 was iat low (I think) 1 was for the dual alternator and the other was ebpv
last night i unhooked the batteries. i hooked them back up after work. the evo said pcm not responding..
i have been researching and read about 15 pages of threads on trannys. a few had pcm problems....
so next question.... where is the pcm located and what do i need to do with it? reflash or replace????
I'm no expert by far. But the little wheels in my head are turning. (They may be turning wrong) after a programmer is removed it leaves traces behind. My truck was chipped by the PO. He removed the chip then when I got it I put a old hypertech programmer in it. I have removed it and upgraded to the edge evo. Has all the programmers confused my pcm????
