Sponsored by: Real Truck
Transmission cooler options
Old May 19, 2012 | 04:35 PM
copracr's Avatar
copracr
I read lots of advice on the 6.0 cooler upgrade, but I was wondering why no one puts an additional cooler on with the factory cooler retained that would be equivalent to one 6.0 cooler?
Just wondering cause the 6.0 cooler is big bucks.
Old May 19, 2012 | 05:24 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The 6.0L cooler is larger and lower restriction. It also bolts into the stock mount. It's the best cooler you can get.
I'm sure you can find other coolers that are better than the stock one, but not as good as a 6.0L cooler.
Old May 19, 2012 | 07:05 PM
copracr's Avatar
copracr
It is pretty big. If I wasn't too concerned about having it mount like a stock one, would it be just as good cooling and "resistance to flow" wise to add a nice stacked plate cooler above my OE cooler?
I'm just thinking I could cover the front of my truck in coolers for the price of one of the 6.0 coolers. But if there is some big reason to use the 6.0 style then I guess thats what I'll get.
Old May 22, 2012 | 05:46 PM
Hondaonda's Avatar
Hondaonda
What about a aftermarket 6.0 vs Factory ford ? Aftermarket 31 row goes for like 280 vs ford 350+
Is there any real diffrence between the two ?
Old May 23, 2012 | 02:17 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Plenty of people put a second, aftermarket cooler on the truck. Try Trucool.
Old May 23, 2012 | 06:08 AM
Mark Kovalsky
The truck comes with two coolers. I think he is asking about adding a third cooler.
Old May 23, 2012 | 01:00 PM
Hondaonda's Avatar
Hondaonda
I was more looking at the actual 6.0 cooler it self ( 31 row not 26 )
parts guy ed wants 405.xx
rock auto is 271.xx
partsgeek is 274.xx
Is there a benefit to buying stock vs. aftermarket for build quality or durability ?
I know with radiators ( similar to a cooler in a way ) there is generally a huge variance within the aftermarket's
ex: Factory ford / Koyo / Spetcra / APDI
In this case the Ford and Koyo are very close as far a fit/finish and quality and the others are much lower on the totem pole
Old May 23, 2012 | 05:40 PM
DND58's Avatar
DND58
26 row is good. @ $280 from Tousley.
Kdr358
Dec 31, 2012 07:04 PM
stimm32
Aug 25, 2012 12:53 PM
tholt34
Mar 21, 2007 01:56 PM
kbeefy
Sep 23, 2006 02:30 PM
670johndeere
Aug 2, 2006 09:19 PM
