2004 F150 key/ignition problem
Old May 19, 2012 | 01:53 PM
texasag00's Avatar
texasag00
My 2004 F150 has a key/ignition problem. The master key started getting stuck when I try to pull it out. Spare key inserts only 3/4 of the way, but still turns over. More concerning is that the spare can be pulled out of the ignition while the engine still is running.
I was considering trying some key lube or powdered graphite first to see if this would free up movement, or do you think I need a new lock cylinder/key set? Or could it be something completely different?
Thanks!
Old May 20, 2012 | 02:28 PM
texasag00's Avatar
texasag00
Nevermind...found an answer to my own question. Thankfully it was a simple answer...no repairs required. I had a phone charger in the power outlet that was blocking the shifter from going all the way into park. As a result, the key was not inserting, removing properly. I moved the charger and park fully engaged, problem solved.
6CylBill
Nov 12, 2009 04:59 PM
mwielgosz
May 22, 2007 10:57 AM
goldielox
2004 - 2008 F150
Dec 23, 2005 08:57 PM
mingiz
Sep 6, 2005 02:28 PM
Peter Nikols
1997 - 2003 F150
Dec 4, 2003 05:20 PM
