EBP Tube Problems
Old May 18, 2012 | 05:36 PM
fordtruck661's Avatar
fordtruck661
EBP Tube Problems
Hi guys I took my EBP tube off to clean it and it turned into a much bigger project then expected. First it was a nightmare trying to brake it loose then once I got it off I could not get it clean. So the question is can I drive the truck with just the sensor hooked up not the tube? I need to order a new tube and sensor so its going to be a few days.
Thanks
Old May 18, 2012 | 05:43 PM
snakedoc's Avatar
snakedoc
yes you can just drive. you will get less mpg then you should but if the tube is plug you will never know it.
you will have less boost but it is only a couple of days.
Old May 18, 2012 | 06:05 PM
fordtruck661
Thats what i thought. That damm tube has never been taken off and the soot got packed in there like concrete. I went through 3 cans of brake cleaner and several different types of wire to try and clean it.
Old May 18, 2012 | 06:11 PM
Franko72's Avatar
Franko72
Molon Labe
Mine has been disconnected for over 50,000 miles. You'll be fine driving it.
I still get 15-19 mpg...
Old May 18, 2012 | 08:32 PM
snakedoc's Avatar
snakedoc
i have all ways read that you can get lower mpg with it off?
Old May 19, 2012 | 01:01 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thats the key word.
No one REALLY understands the EBPS completely it seems.
Is it related to the EBPV? Well... No, but there are documented cases where the two were conflicting.
Does it improve MPG? Sometimes.
How? No one knows, for sure.
I have found VERY little Ford documentation on it.
Old May 19, 2012 | 02:10 AM
twags6's Avatar
twags6
It supposed to affect the fueling tables somewhat. I believe running with it disconnected will also stop the EBPV from activating, since it can't measure the EBP and know when to open back up when you're driving.
Old May 19, 2012 | 02:27 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
That would seem logical, but I have seen NO documentation from Ford saying they are connected.
Old May 19, 2012 | 06:15 AM
OTTOMATIC's Avatar
OTTOMATIC
oh oh I was going to do mine this weekend. It's has never been off.
350,000 mi on truck. Thanks for heads up, I will order new tube.
bigreentruck
Mar 1, 2018 09:11 AM
rwdfan
Jan 23, 2012 11:37 PM
getnbz
Nov 1, 2007 10:24 AM
redfire42
Aug 19, 2007 02:25 PM
Rick2001
Jan 14, 2007 10:51 AM
