Exhaust Back Pressure Sensor and tube
on
[QUOTE=Rick2001]I have heard that there is a new larger diameter tube for the EBP sensor that helps keep the tube from clogging.
Mine is clogged and needs replaced.[/QUOTE
im not sure about the bigger tube.. but if you take the tube off of the sensor you can run a wire down through it to clean it...
