Sponsored by: Real Truck
EBPV tube
Old Oct 31, 2007 | 11:02 PM
getnbz's Avatar
getnbz
EBPV tube
the tube to the EBP sensor is choked up and i tried to take tube off and cant get it loose so i tried to unchoke on the truck that dont work cant get that to work either so i went and bought a stage 2 sensor eliminator at DFuser and it did do the trick any ideas how to get it off so i can clean it out
Old Nov 1, 2007 | 06:36 AM
Pocket's Avatar
Pocket
Spray lots of PB blaster.
Old Nov 1, 2007 | 08:14 AM
getnbz's Avatar
getnbz
is that better than carbarator cleaner
Old Nov 1, 2007 | 08:23 AM
FordTruckNoob's Avatar
FordTruckNoob
Follow the procedures listed here:
http://guzzle.rbmicro.com/ebps.html
Old Nov 1, 2007 | 10:22 AM
fbilly420's Avatar
fbilly420
you need to use penetrating oil not a cleaning solution it will work alot better.
Old Nov 1, 2007 | 10:24 AM
getnbz's Avatar
getnbz
can you take bracket off and remove it i see what looks to be sealant around it because it wont budge the other way
