Transfer case drain plug leaking
Old May 18, 2012 | 05:19 PM
madpogue's Avatar
madpogue
'95 F250 4x4 ZF5, BW1356 lever-op t-case, 163,000-ish miles.
There's a slight leak from the drain plug of the transfer case. It wasn't loose; couldn't find a torque spec on it, but the fill plug is 7-17 ft-lb, and the drain shouldn't be much more (it's not a fastener, after all). It did tighten a few degrees, but I sure don't want to push it - hard steel plug into an aluminum case, no want crack-y. I'm wondering if I should drain it and put some teflon tape on the plug threads. Is that appropriate for an application like this?
Old May 18, 2012 | 07:35 PM
pjwoolw's Avatar
pjwoolw
I use Gasoila on stuff like that. Guzzle has it on his site. Rectorseal, the one with teflon, might be another choice. Teflon tape, to me, tends to increase the possibility of a crack occuring.
Old May 18, 2012 | 08:49 PM
madpogue's Avatar
madpogue
Hey, thanks pj. Dang, I posted this on the 'nation last night; only half the views and NO replies. So I appreciate the reply. Just ordered a tube from guzzle.
Dang, lookit that - guzzle ships on Saturdays! From Colorado, it might just be here by Monday.
Old May 18, 2012 | 09:18 PM
pjwoolw's Avatar
pjwoolw
You really have to work the tube of Gasoila to get it mixed. Takes awhile but its good stuff! Bob ships almost instantly.
Old May 21, 2012 | 10:08 PM
madpogue's Avatar
madpogue
Gasoila came today. You were right; took some mixing. Fluid was about a quart low , and pretty ooky looking. Fortunately we haven't used the 4x4 much.
Old May 22, 2012 | 12:11 AM
madpogue's Avatar
madpogue
Cr@p! Looked at it again. Didn't notice before - crack in the case right at the drain plug.
Has anyone had success welding the case?
Old May 22, 2012 | 12:32 AM
pjwoolw's Avatar
pjwoolw
OH noooooooooooooo!
Old May 22, 2012 | 05:46 PM
ReBilld's Avatar
ReBilld
Here's a rear half on ebay...
1356 Ford Borg-Warner Transfer Case Rear Half / Cover | eBay
Scrib43
1983 - 2012 Ranger & B-Series
Nov 7, 2022 11:53 AM
Fred Chartier
Escape & Escape Hybrid
Sep 5, 2016 09:53 AM
wildtucky
1978 - 1996 Big Bronco
Jan 6, 2013 02:34 PM
triskit16
17
Feb 14, 2009 05:17 AM
dbuck50
Nov 4, 2003 03:47 AM
