6.0L Misfire..
Old Aug 2, 2013 | 07:37 AM
  #46
harris2108's Avatar
harris2108
If its possible to restart this thread I have a similar problem and used my AE to collect some data. However my problem is a miss between 1700 rpm and 2500 rpm, in park or cruising speed.
KOEO - icp 31.72psi IPR% 14.84 FICM 48
Idle - 635psi 23.05 48
2500rpm - 1380psi 47% 48
It has new HPOP, IPR, ICP sensor, FICM, fuel pressure spring kit, new lift pump, 3 new injectors, #1, #3, #5.
Any suggestions would be greatly appreciated.
Old Aug 6, 2013 | 12:47 PM
  #47
WyoFlyFish's Avatar
WyoFlyFish
My truck never did it in park, only while under a load and hot, but it turned out to be a very simple fix. I replaced the EGR Valve. After great stress and headaches, it was as simple as $120 and 5 minutes to replace. I have about 800 miles on the truck without any trouble.
Good Luck, I hope yours is as simple.
Old Aug 7, 2013 | 04:54 PM
  #48
harris2108's Avatar
harris2108
Checked and cleaned the egr, it was also replaced recently.
I changed out the injector wiring harness yesterday and still same problem exists.
I don't have much hair left to pull out!
Old Aug 7, 2013 | 06:57 PM
  #49
04badford's Avatar
04badford
To those who have had bucking, surging, stalling and readings that are wack, take a look at the ICP pig tail, a wiggle test or may have to pull the connection theres a grey clip holding the three wires together you will see burn't or white looking wire corrosion.its time to replace. you wont always see bare wire . I hope this helps I grew gray hair chaseing the problem for almost 2yrs and the truck ran great cold when heated that's when things got weired. its always good to read data from your gauge it could very well be something else, but this is the most common good luck and if you need more help on replacement ,I can help too.
Old Aug 8, 2013 | 12:22 PM
  #50
WyoFlyFish's Avatar
WyoFlyFish
Where would I look for this pigtail? Is there any way I might have wiggled it when I replaced my EGR valve? Truck sure seems to run fine now.
Old Aug 9, 2013 | 12:36 AM
  #51
04badford's Avatar
04badford
NO the ICP on a Early built 03/04 will be under the turbo upper side of Ficm,
late built 04 ICP will be on the passenger side valve/rocker cover, the connection close' to the senser will short under the grey clip. although with heat under the turbo wire will still short .with IPR connection. Make sure when replacement use heat wrap after all connection shrink tube is Installed.
Old Aug 9, 2013 | 03:55 PM
  #52
WyoFlyFish's Avatar
WyoFlyFish
So that goes for the 06 models also? passenger side valve/rocker cover?
Old Aug 9, 2013 | 06:14 PM
  #53
04badford's Avatar
04badford
Yes Sir, the late built 04 and thru 06 is on the Passenger Valve cover
Old Aug 19, 2013 | 12:55 PM
  #54
WyoFlyFish's Avatar
WyoFlyFish
Is it possible to see a picture of the location on the later mods?
If I cant see it in the picture then I will know its behind the turbo...sigh
Old Aug 19, 2013 | 04:59 PM
  #55
04badford's Avatar
04badford
The ICP is the only thing threaded into the valve cover, the connection will be burnt at the grey clip before it connects to the ICP. What year of truck is yours? early built 04 back to 03 will be under the turbo and FICM some say its easyer to remove ficm and some say from under the truck . I would think if replaceing the pig tail I would want to see what I'm doing, Its real easy on the late built 04/06 from the top, In the tech folders on the main page is the 6.0 bible that will show where all sensers are plus some extras stuff to thumb thru
Old Aug 19, 2013 | 08:23 PM
  #56
BLADE35's Avatar
BLADE35
Bud Save this Link below its a 6.0L Bible link TONS of Pics and Info
6.0L Bible Table of Contents
see the Green Air Line that's 2005 ICP location
They are just doing a HPO Systemair test and removed ICP sensor to install the Air line
I have a 2004 6.0L Bible but it wouldn't let me Post the Pic and that's when the change was so its Not In the 2005 Updated changes Bible
And here is the PIC for 2003-2004 Early MY
This came from 6.0L Bible^^^^and there LOTS more in the LINK^^^
Old Aug 20, 2013 | 12:57 AM
  #57
04badford's Avatar
04badford
Thank you Benny ( Blades) I would send the baskit too but made a smoothy instead LOL.
Old Aug 20, 2013 | 09:25 AM
  #58
WyoFlyFish's Avatar
WyoFlyFish
Fantastic! Thank you so much!
Old Aug 25, 2013 | 05:46 PM
  #59
WyoFlyFish's Avatar
WyoFlyFish
Well, it turned out to be both the EGR valve again and the TurboBoost sensor.
I changed the ICP and piggy and it did not help.
Thank you all for your input and help!!
Old Oct 10, 2013 | 12:59 PM
  #60
harris2108's Avatar
harris2108
Problem found!!
Here is the update on my 2003 6.0L, stumble running rough when warm at 1700-2300 rpm problem. I found a piece of spring coil or wire stuck in the RH HP Oil Rail check valve. I assume this affected oil pressure stability at each injector and would not be recorded by the ICP. Hope this helps out.
KC Excursion
May 18, 2017 06:01 PM
ntgcleaner
2009 - 2014 F150
34
Feb 28, 2014 05:24 PM
helifixer
34
Mar 10, 2010 10:23 AM
Torb968
1997 - 2003 F150
Sep 1, 2004 08:35 PM
daimon1054
Modular V10 (6.8l)
30
Apr 1, 2004 06:42 PM
