Perfict AE with the Ford Bundle is Great Just what you need
Set the AE up for cylinder balance and watch it when it misfires or whatever
Also scan for codes maybe you did IDK???????
Check the HPO system to
when you start taking operating values do just like this
Just make shure the numbers are taken exactly like this
Truck in PARK OR NEUTRAL all times during test
ECT at 190* or close to And EOT at 185* or higher
KOEO=Key On Engine Off =record value
Low Idel (truck idel on its own)=record value
High Idel (2500RPM)=record value
Values below are given in this order^^^Left to right
Plug the AE in and check everything
Alittle off topic but FYI any Bulley Dog tuner or Shift on fly tuner is BAD ju ju for the 6.0L
Do you have a list of which sensors to look at when redo this test and what the values should be?
A miss and a buck is not running rough ......................... ??
I guess I do not understand.
I fully understand you said it does it in hot weather. It is not something that you will find a specific TSB on (ie miss and buck in only hot weather). I would recommend diagnosis of the HPO system - including standpipes. I wish you well in your search.
Have you tried selecting 3, or 2, perhaps even 1 on the gear shift instead of just leaving it in D and seeing if you can reproduce the bucking at 2,100 rpm?
I thought about transmission but there is a dirt road I put the truck into 4wd low on the property we go to with the fifth wheel and it still did it at 2100rpm in 4wd low....
On another note I know a guy that has a 2005 and a problem with the gas pedal and since it is all done electrical could this be a sign of a bad position in the pedal?
It only happens at one given RPM. No higher or lower rpm or when it is cold out like winter time. That is what does not make any sence.....
So that should rule out a Bad Torq-Converter Lock Silinoid AFAIK
Your symtoms dont seem Acel Pedal relaited but you can check with that AE at least not from this side computer screen
this thread isnt going to get much farther unless you post some numbers from that AE
ICP
IPR%
FICM
VOLTS
I Tried to send you the values but you dont have enough posts yet
IIRC you need 25posts for PM Ability if it still wont work afetr a post or 2 more I will try and post here for you
Could not get to it today due to more important issues and will try tomorrow but it looks a little full as well.
I will try to get idle information on Ipc and Ipr as well as it at 2500 rpm and engine off. It has been at least a year since I used AE but i believe AE shows ficm voltage as well and will post it when I can get it done....
