Gdub's 1951 panel build
Old May 22, 2012 | 10:55 PM
gdub's Avatar
gdub
4th letter in vin is a 1. Has the 51 latch panel but 52 nosepiece.
Old Apr 3, 2013 | 08:03 PM
gdub's Avatar
gdub
A little gas tank repair.
After I get it all welded up I'm going to cover all the seams with J-B Weld and then use red kote on the inside.
The tank was completely full of this shredded carpet crap. Packrats are great
Old Apr 3, 2013 | 08:49 PM
arctic y block's Avatar
arctic y block
Looks great. more Pics
Old Apr 3, 2013 | 08:59 PM
55f100rod's Avatar
55f100rod
Very nice job!! cant wait to see more progress and follow this build
Old Apr 4, 2013 | 07:57 AM
DR Smith's Avatar
DR Smith
Hope you like to sand.I think the body work,killed any desire I have to do another restoration.
Old May 27, 2013 | 10:51 PM
gdub's Avatar
gdub
Been making a bit of progress the last few weeks. Just about through plumbing the brakes, gotta finish hooking up the rear brakes and get the lines attached to the frame and bleed them. Rebuilt the carburetor, installed new distributor and alternator. After a couple of trips to the junkyard I found the pulleys I needed to be able to have power steering and a/c. Spent the last couple days adapting the Volare Power steering pump to the 302. Actually wasn't too hard after I looked at it for awhile. I used the volare pump brackets and one front bracket off the 302.
Here's where I cut the rear pump bracket(top) and the 302 bracket(bottom).
Cut on the front pump bracket, used the lower part.
Flipped the rear pump bracket and attached it to the engine.
Attached the pump by the lower bolt.
Drilled a hole in the front bracket for the adjustment bolt.
I will still have to do some shimming to get the pump pulley aligned exactly right. Once I get a radiator, wiring harness and get the drive-shaft shortened the mechanicals will be done.
Old Mar 25, 2014 | 09:33 AM
gdub's Avatar
gdub
Thought I better update since it's been a while.Since the last post I've installed upgraded door latches, dual exhaust, brake lines, removed the key from the ford tilt column, got an aluminum radiator fitted, aerostar sparetire carrier, painted the frame/underside of body and adapted a jeep cherokee wiper motor to the stock mechanism, plus a whole lot of little stuff I didn't document.
Mitsubishi door latch in mounting plate.
Dual exhaust
Aluminum radiator 1970 Challenger or Cuda
Spare tire carrier
Body lifted off
Wipers
The chassis is 99% finished, just need to button up a few little things then I need to fire off the engine and get the body mounted again. After that it's finish the bodywork and paint. I've got the majority of the components to get it roadworthy just need the time and some more money.
Old Mar 25, 2014 | 02:37 PM
ben73058's Avatar
ben73058
Hey Gary,
Looking great up there in Canyon!
How do your back doors look? That seems to be a common problem area with the Panels as there are no replacements. What color are you going with?
Ben in Austin
1950 F1
Old Mar 25, 2014 | 03:28 PM
51PanelMan's Avatar
51PanelMan
Originally Posted by ben73058
Hey Gary,
Ben in Austin
1950 F1
I have a pair of rear doors in good shape in case anyone is in need.
Old Jan 3, 2015 | 11:56 PM
Filie's Avatar
Filie
Need alot of parts
Do you know of any read doors for 51 panel truck
Old Jan 4, 2015 | 12:01 AM
Filie's Avatar
Filie
Doors
Do you have rear doors for 51 panel truck email ptfilie@icloud.com
Thanks peter
Old Jan 4, 2015 | 05:23 AM
Filie's Avatar
Filie
Help
Looks good i saw a person on here had two sets
Of rear doors for 51 panel truck how can I find him
Thanks for the help peter
Old Jan 4, 2015 | 09:20 AM
  #28
Jolly Roger Joe's Avatar
Jolly Roger Joe
Thanks peter
Welcome to FTE!
If you want to contact someone whose post you are seeing, click on their username and select "Send a private message to:" or "Send email message to:".
If you're looking for someone and know their username, you can do an Advanced Search for their username.
Or you can do an Advanced Search for a specific topic such as "panel doors".
Old Jan 4, 2015 | 01:40 PM
  #29
Filie's Avatar
Filie
Ok thanks guys learning how to work this
PETER
Old Jan 4, 2015 | 03:41 PM
  #30
bobj49f2's Avatar
bobj49f2
Next to finding an original passenger side seat the doors are most scarce part, as you probably already know. How bad are your doors? Post some pictures. Also, post your location, maybe there's a member near by who can help.
