Did you clean doth sides of the board before plucking the chip in
I scraped off as much silicone as i could with my finger nail then used the scotch brite pad they supplied and took off some more, should the pins be tin colored or copper colored once all the silicone is removed?
Look at the install PDF they have on line to see the how they should look. But you cleaned both sides of the and there's noting stuck in the chips plug. That was my 2 probs
Got it in and running and all i can say is, damn, didn't know a 7,000 lb plus vehicle could accelerate that fast Thanks Jody, James, Diane, and everybody else at DP-tuner. y'all are awsome
Ya know what? That's exactly what I said the first time I hit the throttle with a chip. It started me down the path to get everything I could out of the stock injectors and turbo - and it just kept getting faster and more fuel efficient.
Congratulations, you've taken your first step on the path!
Ya know what? That's exactly what I said the first time I hit the throttle with a chip. It started me down the path to get everything out of the stock in injectors and turbo - and it just kept getting faster and more fuel efficient.
Well, i kinda knew what to expect because i had an 80e tune burned to my PCM last year, but that 120hp tune is just crazy, spun my wheels off the line then chirped them into second, never had something with an auto that could do that. Next thing on my list is the AIH delete, what do i do with the wires on it to not throw a CEL?
I did the AIH delete and I just removed everything except the relay (backup for GPR).
As for the SES light, you'd have to install a thing that regulates the max boost going to the MAP sensor. [LINK]
