No start. Cel. Theft light
Old Apr 5, 2016 | 05:40 PM
tjbradney's Avatar
tjbradney
Well I went to have a guy at work scan my truck to see why my o/d light is flashing
His scanner wouldn't connect so I unhooked my ts chip still wouldn't after that
Now with the chip unplugged. I can't start with it on I can't start
My cel is on and my theft light just blicks
My wait to start never comes on but my glow plugs do start up and warm up
All I have is cranking but that's it
Any ideas?
Old Apr 5, 2016 | 05:47 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Did you disconnect the battery before you removed chip?
Old Apr 5, 2016 | 05:53 PM
z31freakify's Avatar
z31freakify
Did you put it back to stock when you removed the chip?
Old Apr 5, 2016 | 05:54 PM
z31freakify
Did you set the chip back to stock when you removed it?
Old Apr 5, 2016 | 05:57 PM
tjbradney's Avatar
tjbradney
No I never have truck wasn't on
Old Apr 5, 2016 | 05:58 PM
tjbradney's Avatar
tjbradney
Nope didn't think it would change anything
Old Apr 5, 2016 | 06:04 PM
tjbradney's Avatar
tjbradney
Kind of wondering if the pats system won't agree with my key now?
But I'm stuck here at work till my wife brings my spare key to try but i don't get the cel. I have power to my obd2 but it keeps reading error
Edit I unplugged the pats Module. But cel is on and still just cranks
Old Apr 5, 2016 | 06:07 PM
z31freakify
It sure will, one of the members had this same problem put the chip back in the same position it was taken out and set it back to stock and unplug the batts before removing.
Old Apr 5, 2016 | 06:09 PM
tjbradney's Avatar
tjbradney
Problem there is idk which setting it was on
Old Apr 5, 2016 | 06:19 PM
tjbradney's Avatar
tjbradney
What I really don't get is my cel. And why the wts won't show
Old Apr 5, 2016 | 06:48 PM
carltonwebb's Avatar
carltonwebb
Fuse blown?
Old Apr 5, 2016 | 06:58 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
PATS relearn is required.
*THEFT LIGHT (on Excursions) - If the theft light flashes rapidly and the vehicle won't start, the Passive Anti-theft system (PATS) will need to be reset. To reset the*PATS, perform the following steps:
Turn the key on, but do not attempt to start the vehicle.Wait for the theft light to quit flashing rapidly. This should take about 45 seconds, after which the THEFT light will flash multiple times about every 3 seconds.Turn the key off and remove the key from the ignition for 30 seconds.Insert the key and turn the ignition to the ON position.The THEFT light should illuminate for about 5 seconds and then go out.PATS*System should now be resetYou should be able to start your vehicle normally
Old Apr 5, 2016 | 07:10 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Oops. Spoke too soon. No Wait To Start light isn't PATS related.
Old Apr 5, 2016 | 07:27 PM
tjbradney's Avatar
tjbradney
Originally Posted by carltonwebb
Fuse blown?
Not that I've seen I've check pretty much all of them I'm wondering if it isn't getting fuel but hell if I know
Old Apr 5, 2016 | 07:28 PM
tjbradney's Avatar
tjbradney
Haha I tried that reset didn't work I unplugged the pats module anyway
But yeah cel but I can't connect to the obd2. Has power scanner just says error
And the wait to start isn't coming on. But glow plugs cycle
Those two things confuse me
