Time for turbo cleaning
Old 05-17-2012, 01:08 PM
white04kr's Avatar
white04kr
white04kr is offline
I think it's time for a turbo cleaning. 04 with 75k on the clock, on a wot run the boost on sgII says over 28 psi, so let off and I can hear the vanes are still stuck because its still over boosting. Park turn truck off and restart and she runs like a champ all day till another wot run. What do you guys think?
Old 05-17-2012, 01:44 PM
kidoo's Avatar
kidoo
kidoo is offline
Did the same, now have 3000 miles on it without issue. My turbo was overboosting and vane sticking. It was quite dirty, rust and soot, now it run OK.
I now cycle the vane, push it to the floor once in a while and let go, you can see it going to 14 showing it cylces. I do that every tank of fuel while on the road.
Old 05-17-2012, 10:06 PM
Benchwrench's Avatar
Benchwrench
Benchwrench is offline
it could also be the solenoid sticking. Follow the diag proceedure and find the culprit.
Old 05-18-2012, 08:47 PM
03powerstroke6's Avatar
03powerstroke6
03powerstroke6 is offline
i had a problem like this but mine was build up with soot in the turbo. it wouldnt even build boost over 7 psi took it apart and cleaned it now works great
Old 05-18-2012, 09:17 PM
white04kr's Avatar
white04kr
Started pulling turbo 30min to get to turbo with draining coolant. Ran out of daylight so gotta finish in the morning. Hopefully cleaning will solve the over boosting problem. Then install a ww on a buddy's 7.3
Old 05-18-2012, 11:56 PM
Roasted7's Avatar
Roasted7
Roasted7 is offline
My turbo wouldn't boost over 10 psi. I thought for sure it was toast. I disconnected the batteries and did the relearn process. Problem solved. Runs great.
Old 05-19-2012, 02:25 PM
white04kr's Avatar
white04kr
Well finished the turbo this morning and its better then when I bought the truck.
Old 05-19-2012, 09:45 PM
Regulator1988's Avatar
Regulator1988
Regulator1988 is offline
how did you clean it? How long did it take?
Old 05-20-2012, 09:42 AM
white04kr's Avatar
white04kr
For everything prob bout 3 hrs. Just cleaned it with an air powered angle grinder with 2 in disc. Wasn't that bad since I already pulled the turbo to install the egr delete.
Old 05-20-2012, 10:13 AM
Benchwrench
There's a rebuilt thread in the tech folder that might be helpful for you guys wanting to tackle diving into the turbo.
https://www.ford-trucks.com/forums/1...0-vgturbo.html
I found the coarse (brown) 3M roloc discs to safely remove rust and reduce pitting.
messeswithtrux
17
01-05-2020 02:59 PM
hasteranger
11-14-2017 09:14 AM
cookingguy
12-11-2016 12:47 PM
BRay09
12-29-2010 08:28 PM
ram2miller
06-29-2006 11:01 AM
Quick Reply: Time for turbo cleaning
