Do I need a new turbo
So I have been having lots of issues the past few weeks. I have replaced the vgt pigtail and the vgt solenoid. I was still throwing up the vgt code on my scanner, also was have lots of boost issues. So today I decided to pull my turbo. When I got it out I saw the wires for the vgt solenoid sensor were damaged and all tangled up with each other (bare wires). So I repaired them and proceed to pull apart my turbo to clean it and hope that it fixes my issues and I can go on down the road. Well I get it all cleaned up and the vanes are rough and there is alot of pitting on the other parts of the turbo.. So I went ahead and put the truck back together and my turbo just does not want to work very little boost. Is it time for a new turbo? Are the remanufactured turbos ok to use?
Is it possible that when I put the turbo back together I did not have things lined up properly an that is causing my little to no boost issue? By the way I forgot to put the reference mark on it beforbi took it apart. Butbi was able to get it all back together just wondering if something was not right. Or do I have to get a new turbo
The unison ring was not stuck or binding in any way. I know I was supposed to put the reference mark. But I didnot. I got distracted by one of my dogs freaking out and when I got back to the turbo I forgot the mark and just took it apart. I am just wondering if I did not have the unison ring in the right spot. The unison ring did have lots of wear in the lillte hole the actuator goes in. Is there a way to just set the unison ring and the vanes to a certain spot and put it back together and have it work properly
Everything seemed to be moving properly. I just have very little boost. I am thinking it's time for a new turbo
on
I had turbo issues this past spring. Took it apart, forgot to mark everything, and forgot to make sure it spun freely before putting it back in the truck. I put it back in the truck and there was zero boost. I went from a truck with some problems to a truck that was a dog. I took off the air intake tube on the driver's side of the turbo, the one with the air filter attached to it, and figured out that the turbo was not able to spin freely. Took it back apart, and figured out that I had put it back together wrong and the turbo was not able to spin. Fixed it up, put it back in the truck, and then my problem was boost tubes blowing off under boost. I was scared I would crush them if i tightened them too much, so I dove around a little until one end blew off, and then tightened it up some more.
Anyway, my advice is to take that air intake tube off and see if you can move the vanes on the turbo with a screwdriver, etc. If not, take it out, take it apart again, reassemble it again, and make sure it spins freely before putting it back in the truck.
If you have to take it out again, buy a new unison ring for it. Amazon sells them and they deliver in 2 days if you have prime. I ordered something on Thursday and it is sitting on my front porch as I type this.
Edit to add: I watched the video from DieselTech Ron about 20 times, screwed it up. Watched it another 20 times, and then got it right. DieselTech Ron is the man. His videos are extremely helpful. However, I am guessing that you have already watched the video a couple of times.
Amazon.com: 6.0 Powerstroke GT3782va Duramax 6.6 GT3788va TurboÂ*Charger Unison Ring+Gt3782va Vanes 9PCS+GT3782/88VA Rebuild Kit: Automotive
Amazon.com: Ford 6.0 VGT Turbo Unison Ring: Automotive
