is it safe??
Old Mar 17, 2009 | 08:10 PM
messeswithtrux's Avatar
messeswithtrux
is it safe??
to disconnect my wastegate with the mods i have? disconnected it today and the truck runs like mad! thing feels like an airplane taking off. really dont want to blow stuff up though. ive done the search route and didnt come up with much, i know this has been covered but i just cant find it. thanx guys
Old Mar 17, 2009 | 08:17 PM
zx250's Avatar
zx250
Of the next Riffraff East
What was your boost?
Old Mar 17, 2009 | 08:20 PM
Sooper-Doodie's Avatar
Sooper-Doodie
The wastegate controls the amount of boost that your turbo puts out by metering the airflow through the exhaust portion of the turbo. Not only can this save your engine, it reduces the turbine speed of the turbo to make it survive longer.
Old Mar 17, 2009 | 09:42 PM
robs01f250's Avatar
robs01f250
I have mine disconnected right now and i am can see up to 33-34 pounds of boost. Thats not safe on a stock turbo. The stock turbo should only see about 25-27 and on occasion 30 but anything over 30 is just taking away from the life of the turbo. I have had mine disconnected for about 4 months and i seem to be getting better mileage with it unplugged
Old Mar 17, 2009 | 10:20 PM
ernesteugene's Avatar
ernesteugene
No........!
Old Mar 18, 2009 | 12:24 AM
twags6's Avatar
twags6
Originally Posted by ernesteugene
No........!
Gene must be tired. This is the shortest post I've ever seen from him!
The turbo really hates to see more then 25psi because it puts lots of stress on the bushings. The pressure ratio on a stock turbo is about 2:1, so when you see 25 psi of boost, your exhaust is seeing around 50. Unhooking it while stock is ok, but I'd personally hook it back up if I had a DP-Tuner.
Old Mar 18, 2009 | 07:39 AM
dadsgreenpsd's Avatar
dadsgreenpsd
I recently did some towing, and I usually plug in the wastegate while towing to prevent surge. I stopped for fuel, and reconnected it, and the truck had NO power. None. Could hardly make it up hills! Do you suppose the in-line valve crapped out? I had to stop and disconnect it again. I did try to go easy on it, however, after that.
Old Mar 18, 2009 | 09:14 AM
messeswithtrux
yeah, ill check the numbers with it off, then ill put it back on and see the difference. sure does seem to have a ton of power with it off though. sure is fun.
Old Mar 18, 2009 | 09:31 AM
superduty4x4's Avatar
superduty4x4
Go ahead and unhook it, but watch your boost levels. Mine has been unplugged pretty much since I bought my truck, thinking about plugging it back in now that I'm tuned.
Old Mar 18, 2009 | 09:33 AM
Kwikkordead's Avatar
Kwikkordead
I run with my wastegate connected, but with the control rod tightened up to where the WG will not open until the boost hits 12 psi.
For me it's a perfect combination of fast spool up and control from overboosting.
Old Mar 18, 2009 | 09:40 AM
superduty4x4
Good point- my control rod is full tight adjusted.
Old Mar 18, 2009 | 01:16 PM
ernesteugene
Originally Posted by twags6
...Gene must be tired. This is the shortest post I've ever seen from him!...
All posts need at least 10 characters or it would've been even shorter! Here's my most recent discussion on this topic...
Stock and Modded Boost Numbers... This thread is located at:
https://www.ford-trucks.com/forums/s...1&goto=newpost
I figure that by now many people know that if they search the 7.3L section using my username and a key word for almost any topic they'll find plenty of reading material!
BTW whatever became of the "Hippocratic oath"? I just cringe every time I read all the bad advise that's given out to members in this forum!
Old Mar 18, 2009 | 04:43 PM
F250_'s Avatar
F250_
never mind...
Old Mar 19, 2009 | 12:00 AM
twags6's Avatar
twags6
Was I right as far as the ratio of the intake to exhaust pressures?
Old Mar 19, 2009 | 06:05 PM
ernesteugene
Not exactly because it's more complicated than that, but I've not seen any good data for a stock GTP38 turbo. However I have seen data for upgraded turbos and I'll pull together what data I've got and post it later, or maybe I'll wait until I finish the post I mention below!
Here's a "mouthful" from a post I'm preparing on turbos. I've come up with the term AFHP=Air Flow HP to define the "turbine shaft HP" that needs to be applied to the turbine wheel by the hot exhaust gas to power the compressor wheel to pull a given VAF=Volume Air Flow ft^3/min=cfm through the restriction of an air filter element, and then pressurize this ingested VAF, and push it through the restriction of an intercooler, and into the intake manifold to produce a given MAP=Manifold Air Pressure psi, which corresponds to a given BP=Boost Pressure psi, and then through the intake valves with a given VE=Volumetric Efficiency, and into the cylinders to produce a given CAP=Cylinder Air Pressure psi, where VE=(CAP)/(MAP)?
So would anyone like to offer up an estimate of the AFHP that's required to develop a 28 psi boost at sea level?
