distributor position
Old May 4, 2003 | 03:28 PM
blue88EB's Avatar
blue88EB
I am putting a 400 in an 80 bronco and the engine had a loose distributor when I got it how can I tell where the proper position for the rotor is. Thanks for the help.
Old May 4, 2003 | 04:12 PM
Bob Ayers's Avatar
Bob Ayers
Turn crankshaft until cylinder #1 is a TDC on the compression
stroke. You will see the TDC mark on the crankshaft damper.
To check for the compression stroke on cylinder #1, remove the
valve cover, and check to see if the intake and exhaust valves
for cylinder #1 are both CLOSED. If cylinder #1 is at TDC on the
exhaust stroke, both intake and exhaust valves will be OPEN.
After being sure you are on the correct stroke, install the distributor with the rotor facing towards the cylinder #1 post in
the distributor cap.
Good luck!!!
And, welcome to FTE!!!!!
Old May 4, 2003 | 05:13 PM
macguyver's Avatar
macguyver
Easier than pulling the valve cover is just stick your finger in #1 spark plug hole and bump the engine over until you feel air blowing out the hole. Then bring it up to TDC.
#1 plug wire will be toward the master cylinder. Might also be indicated on the cap.
KsCop
39
Dec 30, 2013 05:12 PM
nikwave
Jul 20, 2011 12:00 PM
daniel1982
Apr 26, 2011 04:41 PM
bourbon
Mar 15, 2005 01:42 PM
wiznewski
Aug 27, 2003 10:31 AM
