distributor wires position
Old Jul 20, 2011 | 12:48 AM
nikwave's Avatar
nikwave
i just finished the installation of the new distributor and before cutting the new wires to length i was checking and notice that the wires are not as the shop manual diagram.
the ignition order is fine 15426378 , just the position is different.
i have the #5 to the front instead of #3 as the illustration shows.
my question is how is the best way for routing the wires and how is the best way to move the distributor without messing to much the ignition timing.
Old Jul 20, 2011 | 07:34 AM
Argess's Avatar
Argess
To change the position, you do have to remove the distributor, and re-insert with the rotor shaft re-positioned, and of course the timing has to be re-done.
The key to dist location, is to make sure that over the range of timing adjustment, your vacuum canister doesn't bang up against anything. If that's OK as is, I'd leave it as is, and cut your wires to fit.
Besides, you don't want the wires too tight, plus if you ever wind up with the dist in a different postion, you can probably swap long and short wires around and everything will be OK.
I'd advise you to get a spray can of silicone lube. Fighting with those boots when fitting to the wires can be frustrating otherwise.
And wires for cylinders 7 and 8 should be as far apart as possible, so make allowance for that when cutting lenghts.
Old Jul 20, 2011 | 11:07 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Don't bother rearranging everything by pulling the distributor. Long ago I gave up caring where #1 was "supposed" to be, and just plopping the distributor in and starting from #1 and working counter-clockwise through the firing order. On Fords, that is. For other makes where the distributor turns the WRONG WAY I go the other way
As long as you have enough room to set the initial timing correctly, it doesn't matter which way is which.
Old Jul 20, 2011 | 12:00 PM
nikwave's Avatar
nikwave
ok they will stay like that then ,thanks!!
northdakota 67ford
Jan 4, 2015 09:27 AM
amron
Feb 1, 2013 12:22 PM
Muidem
32
Jun 21, 2011 04:46 PM
Jordan901
Jun 19, 2009 12:09 AM
pknute
Jan 29, 2006 01:55 PM
