Air in cooling system
Old May 14, 2012 | 10:33 AM
Piolet's Avatar
Piolet
Where does the air hide when you fully drain the coolant system and refill it?
When I've done it, it has taken over a week to get all the coolant back into the system, and usually that week is spent topping off about 1.5 gallons of fluid. Engine is hot, engine is cold, tubes are squeezed, degas cap is closed, opened ... doesn't matter ... it wants to take a week.
I have a coolant filter and the fumoto block plugs.
Where is the air hiding?? Could the coolant filter be affecting the purge of the air in the system?? I would have thought that with a good drive and with heaters and a/c's going and the engine up to temp and everything flowing that it would equalize pretty quickly, but it doesn't seem to.
Curious minds need to know.
Old May 14, 2012 | 01:32 PM
steelhead2's Avatar
steelhead2
My guess would be it gets trapped in the heads, towards the back. Being at an angle the way it is theres no other place i could think it would get trapped. Took me 2 days of driving to get my level back to where it was, but i was adding quarts, not gallons at a time.
Old May 14, 2012 | 03:02 PM
cartmanea's Avatar
cartmanea
I actually think it gets trapped in the radiator. If you look closely, you can see the degas reservoir is not the highest point in the system, the upper radiator tank is. I overfill my degas a bit initially and that helps purge the air out faster.
Old May 14, 2012 | 04:39 PM
wulfman's Avatar
wulfman
You have a special child , she is just slow LOL.
Old May 14, 2012 | 04:54 PM
elyrain's Avatar
elyrain
Would parking downhill for the night help at all?
Old May 14, 2012 | 07:13 PM
cartmanea's Avatar
cartmanea
It takes a pretty steep angle to make much of a height difference. I've never had to add more than about a quart after the initial fill. Make sure you get it warm enough that the thermostat fully opens to purge all the air out of the block.
bkuuz1
Jan 12, 2014 06:29 AM
rguy
1978 - 1996 Big Bronco
Jan 23, 2007 09:37 PM
1nascar24fan
Oct 6, 2006 08:17 AM
PAUL_2
Garage & Workshop
Feb 22, 2002 06:00 PM
