1978 - 1996 Big Bronco
coolant air bleeder???
Old Jan 23, 2007 | 07:31 PM
rguy's Avatar
rguy
Is there a way to bleed air from the coolant system? I changed my thermostat, added new coolant, but the gauge is all over the range. It will stay on the "O" for a while, the go past the "L", and make the "engine" light come on. If not air in the coolant system, what would cause this. FWIW, the ambient tempertures are in the 40s and I'm experiencing this problem while just driving around the neighborhood.
Thanks.
Rob
Old Jan 23, 2007 | 09:37 PM
94 XLT White/ Silver 302's Avatar
It sounds like you have a air pocket trapped in the system. I always leave the radiator cap off, fill the radiator with coolant, start it up, then keep squeezing the upper radiator hose to get the air out. Keep a close eye on the temp. I always shut it down when the temp. reaches half way on the gauge.
