Dumb brake questions
Old May 13, 2012 | 08:46 PM
Godlover's Avatar
Godlover
This is my first shot at brake work. Praise God for the Internet and this site.
I mounted the proportioning valve on the frame rail on my 65. My question is what electrical wiring is needed on the proportioning valve. There is the two prong connection on top and looks like a single prong connection at one end. Do i need to do anything with these? My brake light switch is on the steering column.
Question two: I am installing all new lines but can't remember if the caliper line connects at the top of the bracket or the bottom. Does it make a difference?
Question 3: Why is the brake line leaving the master cylinder spiraled? Is this necessary?
Sorry if my questions are elementary. I may not have a lot of knowledge but I am enjoying this project!
Old May 13, 2012 | 11:38 PM
Bill W's Avatar
Bill W
Okay.... the electrical plug in on the porp valve you dont need to hook anything up to it.
you can put the brake light switch there if you want.
question 2: i dont think drum brakes have calipers...but i know what you mean, the rubber hose mounts to the bottom of the bracket, the hard line sticks down
Question 3: the coil in the brake line should be there... it is so the lines can flex between the cab and frame.
Have Fun!
Old May 14, 2012 | 06:20 AM
Godlover's Avatar
Godlover
Have Fun!
Thanks, Question 2: I installed a front suspension from a 79 so I have disc brakes. I installed the 79 hose brackets which are different than the 65.
Old May 15, 2012 | 05:14 AM
jowilker's Avatar
jowilker
Don't sweat the electrical connection or the coil. Sounds like you are on the right track for a great ride.
John
Old May 25, 2012 | 04:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
None.
There is the two prong switch on top and looks like a single prong connection at one end. Do i need to do anything with these?
No wiring of any kind is required.
Proportioning valves have a plastic low brake fluid warning lamp switch that threads into them. Used with the low brake fluid warning lamp on the dash.
Since no 1966 or earlier FoMoCo vehicle has this lamp, just leave the switch in place.
Single pot master: The brake light switch either threads directly into the master or to a brass block that does the same thing.
1967 and later with dual pot master cylinders: The brake light switch mounts to the brake pedal. The type of mount used in 1967 is 1967 only, 1968/79 is basically the same.
1965/77 F100/350: The only switch mounted on the bottom of the steering column is the neutral safety switch, used with A/T.
johnmel59
Dec 11, 2014 02:55 AM
fun98
Apr 4, 2010 08:13 PM
partsman01
Jun 15, 2008 12:58 PM
fordtruck88
Aug 23, 2006 10:25 AM
xman7896
May 18, 2004 01:07 AM
