66 brake question
Old May 17, 2004 | 09:34 PM
xman7896's Avatar
xman7896
66 brake question
I need alittle info from you experts. I have converted over to power disc brakes. I have the brake booster and master cylinder off a 78 f-150. 2 brake lines come out of the master cylinder and go into a transfer like block then branch into the 4 main brake lines. I have no idea what year or model the transfer block came out of and its ugly and old and i want to replace it with a new part. Do you guys know where i can buy a new aftermarket block at?
Old May 18, 2004 | 01:07 AM
cdherman's Avatar
cdherman
That "transfer block" is a proportioning valve. Also has a differential pressure switch that closes when the pressure is too far different between front and rear brakes (so as to tell you that you have a leak or other problem). Anyhow, you have no light for it in your 66, so you can forget about the switch.
The prop valve is the most difficult thing to obtain in the whole front disk swap. They are like $200 new from ford. Being ugly is NOT a reason to discard it. They are all ugly, as they lived in a nastly place. Most still work fine. If you really must have a new one, try www.mpbrakes.com Perhaps parts places can get one too, but prices will be steep, I warn you.
Have you got the flexible brake lines done? Did you move the mounts? If not, the better solution are lines from a 1983-87 Dodge Charger. They have a metal tube up from the banjo block and a little longer hose. They have a metal bracket around the hose that can be removed. Anyhow, using them gets the hose enough extra length and clearance so that it will not get linched in the coil spring if you hit a bump while turning.
Finally, I have a diagram of the prop valve and where to attach everything, but I cannot attach here. email me if you want me to send it to you. It should have 2 lines in (from the top) and two coming out at angles on one end (these are to the front) and only ONE coming out of the other side. That goes to the line to the back. Not four coming out, only 3. If you have 4 coming out, then it was not from a 78' F150. Five fittings total, plus the electric switch between the two line in openings.
