Instrument Cluster Cross-compatibility
Old Dec 2, 2012 | 04:57 PM
subford's Avatar
subford
Originally Posted by ncranchero
Will you clarify that Bill? Mine is a 94 4.9L and I'll be looking for a tach cluster. I don't know if they ever put a tach in a 4.9L truck.
The IP wiring harness is not grounded for a 4.9L but is for all V8's.
Old Dec 2, 2012 | 05:14 PM
ncranchero's Avatar
ncranchero
Glad you mentioned the difference. Now, C101 appears to be the bulkhead connector so the ground shown "should" be in the engine harness, right? Thus the cluster harness should be pinned accordingly and the clusters still interchangable?
Old Dec 2, 2012 | 06:11 PM
subford's Avatar
subford
Yes the clusters are interchangeable.
I think the ground takes place in the engine harness.
Old Dec 2, 2012 | 06:17 PM
ncranchero's Avatar
ncranchero
Had me a bit worried about finding a 4.9L cluster there for a minute!
Old Dec 2, 2012 | 06:21 PM
subford's Avatar
subford
I just added a diagram to show that in my last post above. You might have to hit reload to see it.
Old Jan 18, 2014 | 04:12 PM
boss302429's Avatar
boss302429
Does anyone know if a gauge cluster from a 1991 ford explorer would fit in a 1989 F150? they look the same from the pics I've looked at
Old Jan 18, 2014 | 06:34 PM
Evan_P's Avatar
Evan_P
Doubt it. I am fairly sure they are different in size.
Old Jan 18, 2014 | 06:41 PM
Eddiec1564's Avatar
Eddiec1564
Good question, I have a 93 Explorer and 89 Bronco2, never checked over compatibility of the clusters from the F-series.
Going to check it out tommaro as now as I am curious.....
Old Jan 18, 2014 | 07:00 PM
mefast's Avatar
mefast
I swapped a '96 gauge cluster into my '95 and it seems to be working great so far *knocks on wood* Both trucks had the 4.9l engine. I have pictures of the two clusters on my build thread here: https://www.ford-trucks.com/forums/1...ld-thread.html
Old Jan 18, 2014 | 09:22 PM
Diesel_Brad's Avatar
Diesel_Brad
No. Not even close
Old Jan 19, 2014 | 09:12 AM
fordka's Avatar
fordka
I have one from a 88 f150 id sell
Old Jan 19, 2014 | 10:56 AM
Lead Head's Avatar
Lead Head
You don't even need the cluster. Just get the tach module and gauge module out of a tach cluster and put them into yours. It'll work, my buddy with a 4.9 did it.
Old Feb 6, 2014 | 03:30 PM
  #28
mrrish79's Avatar
mrrish79
So I have a 97 F250HD. If I want to change out the cluster to have a tach I need to get one from a 96-97 Bronco/F150/F250/F350? 94-95's wouldn't work?
Old May 14, 2019 | 11:19 AM
  #29
neanderpaul's Avatar
neanderpaul
5 years has passed
I realize five years has passed. I’m looking for a little tech-support here with my 94 F150. I have a 92 cluster.
Can anyone hold my hand on what modifications I would need to do to my 92 tach cluster to get it to work in my 94?
It will not charge or run properly with the 92 cluster in.
I swapped the 94 cluster without any of the gauges back in and it runs properly
Thanks in advance.
Old May 14, 2019 | 12:40 PM
  #30
subford's Avatar
subford
You need to swap the wire for the charing.
Attachment 283422
1994:
