Instrument Cluster Cross-compatibility
Old May 14, 2019 | 03:18 PM
  #31
neanderpaul's Avatar
neanderpaul
Thank you
Originally Posted by subford
You need to swap the wire for the charing.
1994:
Man, thank you. I appreciate the diagrams. I am sorry but I still don’t understand. If you could hold my hand a little more I would appreciate it. Sorry. I am willing to follow instructions. Thank you thank you thank you
Old May 14, 2019 | 07:45 PM
  #32
subford's Avatar
subford
Move C250 pin #14 Circuit #16 to C251 pin #11.
Move C250 pin #1 Circuit #904 to pin #12 C251
Leave taped back C251 pin #12 Circuit #608.
Move C251 Pin #6 Circuit #29 to pin #5 C250.
Swap C251 pin #2 & #3.
Note you will not have an air bag light in the cluster with Circuit taped back.
Old May 15, 2019 | 12:51 AM
  #33
neanderpaul
Man, that’s above and beyond. Thank you so much.
Old May 15, 2019 | 07:44 AM
  #34
subford's Avatar
subford
Let me know if this works for you. I just looked at the pin locations so I do not 100% guarantee this at all.
But the alternator should charge OK.
Old May 15, 2019 | 10:43 AM
  #35
neanderpaul
You can count on a follow up after I attempt it. Thank you again.
Old May 18, 2019 | 12:40 AM
  #36
eagle275's Avatar
eagle275
Originally Posted by Jermafenser
How about the '97 HD trucks? I have a line on a '96 bronco cluster w/tach that I want to put in my '97 OBS F350.
Should work I have a 96 gasser I'm switching into my 4x4 96 460 truck It almost makes sense to get new guages make up your own panel and stick them in
Old Dec 6, 2019 | 09:01 PM
  #37
Dizy5.0's Avatar
Dizy5.0
I know this is an older post, but I just pucked up a 1996 f350 cluster with tach and want to put it in my 1992 f350, both are 460 gasser trucks. Anyone know what pins need to be switched? Thank you
Old Dec 7, 2019 | 06:33 AM
  #38
subford's Avatar
subford
Would be something like this.
Move C251 pin #11 Circuit #16 to C250 pin #14.
Move C251 pin #12 Circuit #904 to pin #1 C250
Move C250 Pin #5 Circuit #29 to pin #6 C251.
The 1994 above is close to the 1996 except for the ABS circuit in the 1996.
Attachment 282514
Old Dec 7, 2019 | 02:08 PM
  #39
Dizy5.0's Avatar
Dizy5.0
Ok everything works but gas gauge goes past full. Even tried switching back the fuel pins and it still goes past.
Ok found out the pin fuel fuel with tach did not have to be moved to the other plug, on a side note were did you get those pin outs? I have all data diy and they dont have diagrams like that.
Old Dec 7, 2019 | 02:52 PM
  #40
subford's Avatar
subford
Did it work before you swapped cluster?
An open would make the gauge read passed full.
If so you would need to start another thread.
Old Dec 7, 2019 | 03:38 PM
  #41
Dizy5.0's Avatar
Dizy5.0
It did work yes. I updated my post. The fuel with tach was in correct plug. And the fuel without tach just stays as there is no connection on the printed board
Old Dec 7, 2019 | 04:29 PM
  #42
subford's Avatar
subford
They are just from the Ford EVTM's
Old Dec 7, 2019 | 04:50 PM
  #43
Dizy5.0's Avatar
Dizy5.0
thanks again.
Old Apr 11, 2020 | 06:44 PM
  #44
Rbritton's Avatar
Rbritton
Sorry for the bump but...
Trying to find pinout diagrams for an '87-91 F350 gauge cluster. Wiring the original (1988) gauge cluster into a Painless wiring harness for a '77
Old Apr 11, 2020 | 07:26 PM
  #45
subford's Avatar
subford
Rbritton;
Is this what you want?
