smoke problem
Old May 12, 2012 | 08:24 PM
thedon506's Avatar
thedon506
smoke problem
93 F-250 7.3 idi turbo 145K miles.
The truck starts and runs fine, but billows smoke like a steel factory. You'd think my shop was on fire after running it for a few seconds. Its a constant white/greyish smoke. Once the engine is warm it smokes less, but still billowing constant smoke.
The problem developed overnight, not over time. Since it started I've replaced the glow plugs, the fuel return lines (between injectors, filter, and IP. Not back to the tanks yet.) Cleared the injector lines, pulled the injectors looking for defects (no equipment to run a pop test). I cleaned off a bit of carbon from the injectors, but they looked fine. I haven't noticed a loss in coolant or oil yet.
I'm looking for some suggestions before I pull the heads, because that's the last place I can think to look for the problem. I'm thinking head gasket or valve seals, but want to eliminate anything else before I pull off the heads.
Help?
Old May 12, 2012 | 09:13 PM
farmert's Avatar
farmert
What does the smoke smell like? If it is coolant, it will have a sweet smell. Fuel will burn your eyes and lungs if you breathe it.
Old May 13, 2012 | 07:10 PM
thedon506's Avatar
thedon506
Definitely smells like fuel. I found a couple cracked o rings on my injectors. Ordered a kit today with new o rings and caps. hopefully that solves my problems.
94 7.3idi
62
Oct 6, 2022 02:38 PM
mitchell390
Mar 2, 2015 06:48 AM
thedon506
May 13, 2012 04:58 AM
ziffle
Jun 28, 2006 09:51 PM
SMACUSTOMS
Oct 31, 2005 09:07 PM
