diesel problem
Old May 12, 2012 | 08:12 PM
thedon506's Avatar
thedon506
diesel problem
93 F-250 7.3 idi turbo 145K miles.
The truck starts and runs fine, but billows smoke like a steel factory. You'd think my shop was on fire after running it for a few seconds. Its a constant white/greyish smoke. Once the engine is warm it smokes less, but still billowing constant smoke.
The problem developed overnight, not over time. Since it started I've replaced the glow plugs, the fuel return lines (between injectors, filter, and IP. Not back to the tanks yet.) Cleared the injector lines, pulled the injectors looking for defects (no equipment to run a pop test). I cleaned off a bit of carbon from the injectors, but they looked fine. I haven't noticed a loss in coolant or oil yet.
I'm looking for some suggestions before I pull the heads, because that's the last place I can think to look for the problem. I'm thinking head gasket or valve seals, but want to eliminate anything else before I pull off the heads.
Old May 12, 2012 | 11:55 PM
Phy's Avatar
Phy
Try posting this in the IDI forum. You'll get a lot of responses...
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums
A bad injector can cause white smoke. How many miles on the injectors & pump?
In any event, I'd do a compression test before pulling the heads...
Old May 12, 2012 | 11:58 PM
Phy's Avatar
Phy
Whoops, just saw that you did post in the IDI forum...
Old May 13, 2012 | 02:48 AM
popupJunky's Avatar
popupJunky
What color is the smoke
Old May 13, 2012 | 04:57 AM
XLT89F350cc's Avatar
XLT89F350cc
[quote=thedon506;11825077]93 F-250 7.3 idi turbo 145K miles.
Old May 13, 2012 | 04:58 AM
XLT89F350cc
You'd think my shop was on fire after running it for a few seconds. Its a constant white/greyish smoke. Once the engine is warm it smokes less, but still billowing constant smoke.[/quote]
XLT89F350cc
that didnt work the way i wanted it to, sorry
mitchell390
Mar 2, 2015 06:48 AM
thedon506
May 13, 2012 07:10 PM
diamondwsr
Nov 21, 2011 04:26 PM
ziffle
Jun 28, 2006 09:51 PM
sean23johnson
May 26, 2005 09:00 PM
